Author Topic: Ultra Wide IPS for 149  (Read 2329 times)
« on: November 11, 2015, 01:58:45 pm »
http://www.newegg.com/Product/Product.aspx?Item=N82E16824025212&nm_mc=AFC-dealnews&cm_mmc=AFC-dealnews-_-NA-_-NA-_-N82E16824025212
I'm just posting it because I thought it might be a good alternative to the 3 monitor setup.  That being said they are still measuring diagonally, so I'm not sure if the dimensions are large enough to be relevant.
vwalbridge
Re: Ultra Wide IPS for 149
« Reply #1 on: November 11, 2015, 02:01:59 pm »
Careful. The way things are going these days...that thing will end up in someone's cab as a digital marquee.
« Reply #2 on: November 11, 2015, 02:13:14 pm »
25 is pretty small for ultra-wide.  I guess you could just mount it closer.  :D
I'd make sure it has a VESA mount. EDIT: It has VESA mount, had to click the spec tab instead of the spec section.
Monitor is only 11" tall without stand. (11.30" x 24.00" x 2.20")
I still think the 180 degree wrap around view is more desirable.
« Last Edit: November 11, 2015, 02:15:35 pm by BadMouth »
« Reply #3 on: November 11, 2015, 02:25:53 pm »
You say that like it's a bad thing.  Honestly with the 50 bucks for plexi and the 30-50 bucks to get a marquee properly printed, it's starting to become economically viable.  Spend 100 for a marquee or 140 for a screen with all the marquees.  ;)
vwalbridge
« Reply #4 on: November 11, 2015, 02:29:29 pm »
Yea, my initial reply was said Tongue-in-cheek. I agree, while maybe not the perfect screen ratio, it's certainly becoming more economically viable by the day.
