Author Topic: 412-1 JAMMA board - Track ball question  (Read 3433 times)
Porsch964
  • Last login:January 18, 2016, 07:55:53 pm
« on: November 11, 2015, 12:52:29 pm »
Question about how to connect my track ball to the 412-1 game board.
I purchased a 3" Blue Trackball, by Happ and Made in USA
Durable polycarbonate
3" diameter
Standard AMOA harness included
It appears the wiring harness connection is different.  I also purchased a harness for a 3" interface and neither of the connection seems to fit.
What do i need to do?
thanks for any help.
behrmr
  • Last login:April 23, 2021, 09:17:13 am
behrmr
Re: 412-1 JAMMA board - Track ball question
« Reply #2 on: November 11, 2015, 01:45:43 pm »
You can also hack the harness and feed it +5V and GND from your switcher PS. Then wire the clk and dir from the optic boards to up/down and left/right
Porsch964
« Reply #3 on: November 12, 2015, 12:02:48 am »
first, thanks for the help!
I've actually got the wiring harness you mentioned above, but my connection is different.  The jamma interface has 4 connections versus one.
Please review hyper link to see example
http://www.amazon.com/gp/product/B00907T8LQ?psc=1&redirect=true&ref_=oh_aui_detailpage_o09_s00
"You can also hack the harness and feed it +5V and GND from your switcher PS. Then wire the clk and dir from the optic boards to up/down and left/right"
Laymans terms - connect the +5 and Ground from my power supply.  Wire direct to the black connector on the mother board?
Since ive got the wiring harness, i need to understand why ive got four connections and possibly create a new connector?
« Last Edit: November 12, 2015, 12:16:12 am by Porsch964 »
behrmr
« Reply #4 on: November 13, 2015, 11:27:29 am »
Do you have this harness? http://www.hollandcomputers.com/store/pc/JAMMA-Trackball-Interface-Wiring-Harness-for-3-Trackball-for-138-in-1-276-in-1-352-in-1-412-in-1-PCBs-2515p8035.htm
It should be plug and play. Plug into your 2 optics then to the header on the PCB.
The "hack" would be:  Wire the +5V and GND from each optic to your power supply or tap into the JAMMA harness itself in whatever way you like to - cut/solder/butt splice/scotch locks/whatever.  Then your 2 directional wires for each optic become up/down and left/right.  Wire those to the JAMMA harness wires from pins 18,19,20,21.
Disclaimer:  That *should* work. It's been a while since I've done one.  If it doesn't and you have a munched up harness when you're done don't blame me.
Porsch964
« Reply #5 on: November 19, 2015, 01:19:51 pm »
thanks for the help.  I needed to remove the original harness from the two PCB boards.
All is good.   My fault... thanks for the help
behrmr
« Reply #6 on: November 21, 2015, 12:47:50 am »
Glad you figured it out.
