Author Topic: golden tee 2016  (Read 3161 times)
eazygamer
  • Last login:November 25, 2015, 07:17:02 pm
golden tee 2016
« on: November 10, 2015, 09:54:03 pm »
Hello everyone, I am new to this board, I  have read a few theads, and I am amazed how knowledgeable everyone is on here.
Right now I own a 2012 gt live, and looking for the least expensive way to upgrade it to the current 2016.
A friend of mine just bought a 2016 update, it only came with a hard drive and a 8 pin ic for the i/o board.
Well it has me thinking, I can make an image of the hd, but has anyone ever copied the 8 pin ic?
  • Last login:November 19, 2025, 06:31:36 pm
Re: golden tee 2016
« Reply #1 on: January 12, 2016, 02:24:09 pm »
not happening.
the 8 pin dip is a security chip. they are pre-programmed and bit locked...they may even be destructive locked where if you try to dump the data out, it wipes the chip.
the ONLY way to upgrade is to call IT and tell them what version you have and they will supply you a chip and USB thumb drive that will update the software on the drive to the new version.
there is no "cheap" way to do it because IT holds all the cards in this system. it was done this way intentionally so you have to buy product from them.
this is also why they don't supply re-installation disks...they'd rather you bought an over priced pre-loaded hard drive from them.
ed12
Re: golden tee 2016
« Reply #2 on: January 12, 2016, 03:22:29 pm »
plus there is other reason's
least of which is the blackhawk cpu system is different on 2013-2015 then in 2012.
video/cpu/etc
ed
« Last Edit: January 12, 2016, 08:16:24 pm by ed12 »
Re: golden tee 2016
« Reply #3 on: January 12, 2016, 06:07:15 pm »
video/cpu/etc
ec
this is okay because they inserted the older board drivers into the OS in the newer versions.
it gets a little interesting to try and use newer hardware in older games because the drivers aren't in the OS until specific versions. for instance...video cards:
http://amusement.itsgames.com/downloads/instructions/Video%20Card%20Compatibility.pdf
you have to have specific versions of certain years in order to be able to use a replacement videocard. i've had to do the video card shuffle to fix an older 2010 with a failed 9500GT by getting a new card and swap,swap,swap the new 740 from a 2013 with a 640 from a 2012 to get a 430 that would work with 2010.
ed12
Re: golden tee 2016
« Reply #4 on: January 12, 2016, 08:17:26 pm »
dido on that 1.
then the dif between home and commerical..
ed
