First, yes I've sent an email to Andy.
In case he can't figure out the issue, I wanted to see if any of you have had experience with this.  I'm all out of ideas here.
 Problem: ULTRAMAP will only recognize one Ultrastick 360 joystick at one time (despite both having different ID#).  Windows detects the joysticks fine as Ultrastick #1 and #2... all buttons work and joysticks work.  Oddly enough, I can move the crosshair in the little preview window in ULTRAMAP by moving the joystick, even though ULTRAMAP says it's "not detected."
Other Details:
1) Windows 7
2) I've tried restarting, unplugging all USB cables, reinstalling ULTRAMAP.  None of those work.
3) If only one joystick is plugged in, ULTRAMAP detects it fine as #1 or #2.  The instant you plug in #1... #2 goes grey and is "undetected."
Other Other Details:  Everything was working fine with both controllers until I let one of the USB cables get too taut.  It ruined the PCB board for joystick #1, so I had to replace it.  The new PCB board could not be detected, so I reinstalled ULTRAMAP... now it detects #1 fine... but it won't detect both joysticks at the same time.
Please help!  My head is about to explode!
