Author Topic: Use T-molding like a marquee retainer  (Read 1502 times)
fablog
  • Last login:November 26, 2025, 06:59:35 pm
« on: November 07, 2015, 02:19:18 pm »
I'm wondering if I should buy the Happ black retainer or use a white T-molding for the  marquee. I prefer the T-molding for the color, because I want  a Blip style cabinet (black & white), but the Happ retainer seems a flawless installation. Is the T-molding a good aesthetic solution?
markc74
  • Last login:November 27, 2025, 06:32:39 pm
  • Flipping out
Re: Use T-molding like a marquee retainer
« Reply #1 on: November 07, 2015, 02:59:58 pm »
That's exactly what I did.
Use a router and cut out a 3mm (or whatever thickness your perspex is) channel near the edge and the perspex just slots into that. As long as your marquee is at a 90 degree angle to the speaker panel and top piece it should be fine. I've attached a pic to show how mine works
Edit - sorry misread the original question. In terms of aesthetics I think it looks cleaner than marquee retainers, as like you say, you can choose any colour and there's no visible fixings. However - I don't know how well the slot will hold up if I had to take the perspex out a few times. I've done it a couple of times without issue but I assume there must be a good reason why more people don't do it as its a fairly straight forward process with a router. And cheaper than retainers.
« Last Edit: November 07, 2015, 03:23:09 pm by markc74 »
fablog
« Reply #2 on: November 07, 2015, 09:58:22 pm »
Thanks a lot Markc, it's crystal clear and it help me a lot :)
SavannahLion
« Reply #3 on: November 10, 2015, 12:44:52 am »
The thought had crossed my mind (not sure if I saw it on a project or not) and I always assumed more people don't do it because commercial cabs don't do it. The rest just don't think of it I guess.
Depending on the design, I suppose you can make the top most panel hinge open. That way you can avoid pulling out the T-molding for maintenance. Not lime it's going into a commercial setting.
