March 11, 2026, 06:37:34 pm
That should work, my only concern would be with the mdf separating over time.
Getting that 1/8 back is not likely a problem with MDF. Just make sure you screw and glue it well in a number of places. Also, I came back to add in to make sure you clamp it until the glue dries completely so the screws are not the only thing pulling the two pieces together. Screws tend to rip out of MDF when under pressure so rely on the glue to do the majority of the work.
