Author Topic: Need your help. Stickykeys / Hotkeys  (Read 966 times)
Nacimroc
  • Last login:October 20, 2015, 03:46:25 pm
« on: October 20, 2015, 03:10:07 pm »
I have a PC running on windows 7 with maximus arcade. The problem I'm having is the screen keeps rotating 90 degrees when a certain combination of buttons are pressed. CTRL+ALT+UP/down etc. Basically its buttons 1,2 and joystick movement which are commonly pressed together. I've disabled hotkeys in the graphics settings but its still happening.
Is there any way to make it so buttons can't be pressed together and if so would this screw up gameplay ?
JDFan
Re: Need your help. Stickykeys / Hotkeys
« Reply #1 on: October 20, 2015, 03:18:05 pm »
Could reassign the key for button 1 so that it is not CTRL  :dunno
Nacimroc
« Reply #2 on: October 20, 2015, 03:24:49 pm »
To add to the confusion, I no longer have the control panel. I sold the arcade machine and the guy just posted back the PC only.
Hoopz
  • Last login:November 16, 2025, 09:21:03 am
  • Intellivision Rocks!
« Reply #3 on: October 20, 2015, 03:41:45 pm »
It's probably a video card setting.  Can he pull up the software for the video card and disable those hotkeys?  If you know what software is on it for the graphics properties, it'll help.
