Author Topic: Oak & Android, a handheld arcade  (Read 2729 times)
Dafu
  • Last login:October 05, 2015, 10:06:43 pm
« on: October 04, 2015, 09:56:14 pm »
Hi all,
I've just made my 3rd arcade "cabinet". This one is something a little different, inspired by the WiiU.
Video of the handheld in action:
Full album with progress shots:
http://imgur.com/gallery/539KO
Slippyblade
Re: Oak & Android, a handheld arcade
« Reply #1 on: October 05, 2015, 02:05:21 am »
Interesting build.  Looks nice!
scoodidabop
  • Last login:September 05, 2025, 12:20:38 am
« Reply #2 on: October 05, 2015, 10:54:59 am »
Sometimes you don't realize you need a thing until you see it.  Now I need this. Such a neat little build!  Any chance you might share the UI/frontend that you wrote?
Great work!  :cheers:
pixelObsession
  • Last login:September 09, 2025, 05:54:20 pm
  • Product of the 80's
    • Pixel Obsession
« Reply #3 on: October 05, 2015, 03:21:17 pm »
When you loaded Galaga I was hoping you were going to rotate the pad 90 degrees counter clockwise and use the analogue and buttons that way ;). Really slick build, Love these handheld arcades!
Dafu
« Reply #4 on: October 05, 2015, 06:31:46 pm »
I've shared the source code for the Launcher, but not the UI overlay that shows volume/exit timer. Its all hard-coded and not very flexible at all. You can find the link to the source code and a lengthy explanation into what the software worked involved at:
https://www.reddit.com/r/MAME/comments/3nh9db/oak_android_handheld_gaming_system/
Dafu
« Reply #5 on: October 05, 2015, 06:40:39 pm »
I'm not entirely happy with the buttons and joystick on this built, maybe you guys have some alternatives you could share?
The buttons used here are from:
http://www.adafruit.com/products/1505
and the 4way (semi 8way if you get it right in the corner) joystick is:
http://www.digikey.ca/product-detail/en/04A/GH7453-ND/2138040
Both of these are functional but not great.
The buttons have low quality switches, if you can even call them that. They're essentially a washer on a spring that when pressed down makes a contact when you bottom out the button completely, any release on pressure opens up the switch. The buttons also take considerable force to press down.
The joystick also takes quite a bit of force, has long throw, and the shaft presses down into the joystick assembly pointlessly without actually being a switch. It also feels rough and "grindy".
What are some alternatives? The buttons must be 16mm and the joystick should be about the size of a Playstation analog thumb stick.
Slippyblade
« Reply #6 on: October 05, 2015, 06:53:18 pm »
...and the joystick should be about the size of a Playstation analog thumb stick.
Have you thought of just using a PS thumb stick?
Dafu
« Reply #7 on: October 05, 2015, 07:22:30 pm »
I have, but I'm currently using a keyboard bluetooth controller. An analog stick would require a gamepad bluetooth controller, I don't have one to sacrifice at the moment, but it might have to come down to that. There isn't much to pick from for controls of this size:(
Slippyblade
« Reply #8 on: October 05, 2015, 07:24:50 pm »
Got it, encoder limitations...
Unfortunately, that Grayhill stick is the go-to for micro builds.  There really isn't a lot available in that realm.  If you manage to find/hack/cobble something please post it!
Dafu
« Reply #9 on: October 05, 2015, 08:14:59 pm »
That's unfortunate. Any suggestions for buttons?
Dafu
« Reply #10 on: October 05, 2015, 09:49:01 pm »
Slippyblade
« Reply #11 on: October 05, 2015, 11:15:43 pm »
Hell, for $5 it'd be worth an experiment.
  • Last login:Yesterday at 10:47:28 pm
« Reply #12 on: October 05, 2015, 11:42:44 pm »
Has anyone tried this thumbstick from arcadeshop.de?
