Author Topic: Advice prepping panel for artwork please  (Read 1650 times)
Jimbo
    • Wood Finishes Direct
« on: October 03, 2015, 05:34:50 am »
I've got 3 panels to prep for the artwork I've just received from GameOnGrafix for my rotating CP project.  Each panel has either aluminium joystick mounting plates or some clear plexiglass (for edge lighting) to cover up.  I have some filler to fill in around the edges of the mounting plates/plexi and the screw holes etc, but due to the CP design and difficulty in lining up the artwork as accurately as possible, I'd really prefer to wet-apply the CPO so I need the panels completely non-porous before application.  Scott at GOG has assured me that this should be fine with the adhesive-backed polybanner overlays he's sent me.
So I have in mind one of the following options...
1) watered-down PVA glue
2) shellac sanding sealer
3) nitrocellulose lacquer spray
I need something that will adhere to plywood, aluminium and plexiglass to make the whole CP surface uniform/flat and non-porous.
Before I go ahead and experiment with the above methods on some off-cuts, I thought I'd try and save some time and energy by asking for some advice on here.  As you can see in the photo, the CPO also has to wrap around the 60 degree edges at the front and rear of each panel.
Any advice welcome!
EMDB
  • Project RetroCade
Re: Advice prepping panel for artwork please
« Reply #1 on: October 03, 2015, 07:20:10 am »
There's really no need to wet apply the polycarbon CP overlay as it is so thick it will not leave air bubles  or crease. Just sand, primer  and sand and it will attach just fine.
Regarding the lining up: I used a flashlight to light from below and perfectly position the overlay. Fixate it with clamps and just than peel of the adhese layer from one side and stick it to the CP. Afterwards I cut out the holes for the buttons / sticks with my router using the flush bit
Jimbo
« Reply #2 on: October 03, 2015, 12:28:14 pm »
Hey thanks - your panel looks great.  Nice idea with the flashlight and clamps. :)    What primer do you recommend?
EMDB
  • Project RetroCade
« Reply #3 on: October 08, 2015, 05:37:06 pm »
Any will do I guess...
shayvidas
  • Last login:March 28, 2016, 09:18:22 pm
  • mame Fan Forever !!!
« Reply #4 on: October 09, 2015, 05:35:10 am »
woww nice mounting for your Joystick !!! can you pls explain how you mounted it so it will fit like this ?
EMDB
  • Project RetroCade
« Reply #5 on: October 09, 2015, 11:02:31 am »
Disadvantage is you can never unmount / replace it without screwing up the CP overlay. Undermount is the way to go  :cheers:
  • Last login:November 17, 2025, 12:55:58 pm
« Reply #6 on: October 09, 2015, 12:08:55 pm »
I've always used Rustoleum Black Gloss paint.  No need for primer as it's built in.  Once dry and cured, the gloss finish is great for applying artwork with adhesive.
http://www.walmart.com/ip/Rust-Oleum-Universal-Spray-Paint-Gloss-Black/17011121
Edit:  Just make sure you properly mask off the plexi if you are spraying.  You don't want any to ruin the lighting effects!
D
« Last Edit: October 09, 2015, 12:11:01 pm by DeLuSioNal29 »
Jimbo
« Reply #7 on: October 09, 2015, 02:41:00 pm »
I top mounted as I wanted the height of the joystick just right for me.  Undermounting didn't feel right.  Basically I routed out a 2.5mm area for the mounting plate.  The joysticks are dominux8's so luckily I can still replace the shaft/grommet if needed.
« Last Edit: October 09, 2015, 02:43:34 pm by Jimbo »
Jimbo
« Reply #8 on: October 09, 2015, 02:41:39 pm »
D
Thanks - will take a look  :cheers:
shayvidas
« Reply #9 on: October 10, 2015, 02:56:36 pm »
sorry for being such a noob...
so wait.. amm.. so you routed a small hole for the square of the joistick and the main plate just sits on top of the wood ? and youve put screws directly to the wood ?
so in theory the height of the metal plate is on top of the wood (sticks out a little bit ?)
sorry again for the noob question
shayvidas
« Reply #10 on: October 10, 2015, 02:58:08 pm »
i mean how do you make the metal plate so flush with the wood ?
EMDB
  • Project RetroCade
« Reply #11 on: October 10, 2015, 02:59:47 pm »
just route out a pocket exactly the height of the metal plate  :laugh:
Jimbo
« Reply #12 on: October 10, 2015, 03:02:01 pm »
It helps to have access to a CNC router!  ;D
shayvidas
« Reply #13 on: October 11, 2015, 02:42:28 am »
hey if you had a CNC router that's cheating ;)
