Author Topic: input through a 3.5mm Antenna Jack?  (Read 2059 times)
Sanban
  • Newbie
  • Last login:January 07, 2004, 02:45:47 am
« on: January 07, 2004, 02:54:16 am »
I'm trying to build a fully functional really small cabinet for a conversation piece or something(or maybe as a test run incase I ever want to do something bigger.)  It's essentially an Nes board with a pro-wrestling cart.  The screen I'm trying to use is a 5" or so b/w ntsc tv.  The problem I have is that the only input to the monitor is the 3.5mm antenna jack, while the nes outputs video either as a coax or RCA composite.  I seem to remember having an adapter from the 3.5mm to a dual lead antenna connection, but I don't think that worked with the nes.  The other problem is that this TV does not have set channels, it's like a radio dial.  I need the tv to be set at exactly channel 3 or 4.  Does anyone see any easy solution to this or am I going to need to do some complicated modifications to the TV board?
knuttz
  • Last login:January 08, 2025, 05:36:02 pm
Re:input through a 3.5mm Antenna Jack?
« Reply #1 on: January 07, 2004, 03:34:31 am »
Radio Shack does sell a 3.5mm to F connector (coax) connector adapter.  I'm almost positive if you use that connector with your RF switch (gray box) that came with the NES and tune the TV to VHF channel 3/4 you will get the signal you want.  Just turn the NES on and hunt around for the signal with the dial while the TV is on the VHF band.
"Look at all those hamburgers. You can't eat all those hamburgers you stupid fella, OH GEEZ!" "OH he's gonna do it! He's so rediculous."
