Author Topic: Tron CP Spinner replacement (SpinTrak or SlickStik Tornado)  (Read 1764 times)
jonnylbluejeans
  • Last login:November 29, 2018, 09:04:28 pm
« on: September 26, 2015, 06:12:41 pm »
I have a Tron control panel and need a USB spinner to install in the CP.  Which is easier to install, the SpinTrak or the SlickStik Tornado.  (Can they simplly bolt in?)
megamoze
  • Last login:December 18, 2024, 04:05:59 pm
  • Loving my cabinet, built summer 2015
Re: Tron CP Spinner replacement (SpinTrak or SlickStik Tornado)
« Reply #1 on: September 27, 2015, 12:22:51 am »
I have the SpinTrak and it was very easy to install.   It basically installs like a button.
aldub516
  • Last login:November 29, 2018, 03:32:46 pm
« Reply #2 on: September 27, 2015, 10:01:56 am »
I've only used a spintrak but I assume they're all the same. The just go in the same hole as a button would.. And the wiring depends on what set up u have but its just one ribbon plug
  • Last login:Today at 12:17:33 pm
« Reply #3 on: September 27, 2015, 10:27:28 am »
For ease of installation, go with either the SpinTrak or the TurboTwist 2 from GGG.
Both are installed like a button in a button-sized (1-1/8") hole.
The Tornado uses four screws to mount to the underside of the panel.
Bottom view showing two of the mounting holes:
