Author Topic: FR/FT/FS: Twilight Zone Pinball, Orange County, SoCal  (Read 831 times)
jasonbar
  • Dr. Inferno
    • The Infernolab
« on: September 26, 2015, 05:42:30 pm »
[Repair advice welcome but, due to logistics, can't be accepted & acted on at this time].
Twilight Zone.
Bally/Midway, 1993, DMD.
1st Choice: Seeking Electrical Repair
2nd Choice: For Trade (contact me for my wish list)
3rd Choice: For Sale for $5,500
Lots of upgrades.
A couple of electrical issues.
Otherwise solid, clean, & mechanically sound.
The cabinet is about an 8/10. Some fading/scratches/nicks. The PF I'd put say 9/10 (but I'll be conservative & say 8/10).
Electrical issues:
1 - Nagging switch matrix issue. U20 on the MPU (now socketed) blows & usually (but not always!), column 4 goes out. Sometimes after a couple of minutes, sometimes after a couple of months, with no discernible pattern or consistent culprit. Troubleshooting has cast suspicion away from the following culprits by disconnecting them, swapping them, inspecting them, etc.: MPU PCB, coin door, The Power mini PF, magnets, all flasher bulbs, actuating coils, Great Lakes opto board, clock. That pretty much leaves wiring (probably in the flashers or switches?) as a culprit. Most wire bundles have been inspected visually & loosened.
2 - Slight audio crackle on some quiet callouts.
3 - Clock PCB opto(s).
Summary of work done on it in the last ~1.5 years (and a few items put in by the previous owner in preparation for selling it to me):
a) New leg levelers
b) Cleaned up leg rust by hand
c) Patched minor cabinet holes/nicks
d) Touched up cabinet paint at holes & other chips
e) Painted glass lock bar, side rails, & shooter rod housing with Rust-Oleum Hammered Black, then clearcoat spray
f) Cleaned up translite--it was taped heavily to a Plexiglas panel (instead of glass), a bit of tape remains
g) Tasteful color-matched LEDs throughout the whole machine, including flashers
h) All new white rubbers
i) Pulled off a few key PF items for better access & then cleaned, polished, & waxed the PF
j) New steel balls
k) Left spiral aftermarket bulb sign kit
l) Pinbits door insert flasher kit
m) Pinbits gumball sparkle flasher kit
n) Plastic Pachinko "gumballs" into gumball machine
o) New upper right flipper entire assembly
p) Replacement score cards from Marco
q) Decal for cross-ramp ball diverter
r) Anti-bounce-out magnets on cross-ramp ball diverter
s) Polished Power Ball
t) New leg bolts
u) New blue Pincab protectors
v) New Great Lakes magnet flipper board (for right flipper, a GL magnet flipper board was already installed on the left)
w) New left speaker
x) New backbox data ribbon cable
y) New X9503P DIP8 IC for audio board, to remove random volume increase/decrease
z) New LM19875 audio amp to lessen occasional crackle on quiet sound calls
aa) New Kahr WPC MPU Power Fix Circuit PRO [LATER REMOVED--SEEMED TO BE CAUSE OF RESETS]
ab) 8 new caps on audio board per PinWiki recommendation for audio weirdness
ac) Great Lakes Modular opto PCB
ad) New backbox lock & keys
ae) Remote 3x AA battery backup [RECENTLY DISCOMBOBULATED BY LEAKY BATTERIES--HAVEN'T REPLACED IT SINCE THE AA MELTDOWN]
af) Newest 9.4H ROMs
ag) Replaced umbilical cable shroud from backbox to cabinet--stock one disintegrated
ah) New replay knocker
ai) New tilt plumbob weight
aj) Pinball Inc. DMD-HVP High Voltage Piggyback board on top of original Dot Matrix Controller Board
Thanks,
-Jason
« Last Edit: September 26, 2015, 05:45:15 pm by jasonbar »
