Author Topic: Controller Remap Utiility - SOLVED!!!  (Read 2638 times)
lisowskikevin
  • Last login:April 02, 2024, 07:49:55 pm
  • If you take shortcuts, you get cut short.
« on: September 19, 2015, 07:07:24 pm »
Hey guys I was muddling through the utility and accidentally deleted something in one of the windows and now everytime I strat the GUI I get this message
Microsoft .NET Framework
Unhandled exception has occurred in your application. If you click Continue the application will ignore the error and attempt to continue. If you click quit the application will close immediately
Conversion from type DBNULL to type String is not valid
then I click on details and I get this...
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.InvalidCastException: Conversion from type 'DBNull' to type 'String' is not valid.
   at Microsoft.VisualBasic.CompilerServices.Conversions.ToString(Object Value)
   at CtrlRemapGUI.ControllerRemapGUI.Load_Ctrls()
   at CtrlRemapGUI.ControllerRemapGUI.InitialBoot(Object sender, EventArgs e)
   at CtrlRemapGUI.ControllerRemapGUI.Form1_Load(Object sender, EventArgs e)
   at System.EventHandler.Invoke(Object sender, EventArgs e)
   at System.Windows.Forms.Form.OnLoad(EventArgs e)
   at System.Windows.Forms.Form.OnCreateControl()
   at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
   at System.Windows.Forms.Control.CreateControl()
   at System.Windows.Forms.Control.WmShowWindow(Message& m)
   at System.Windows.Forms.Control.WndProc(Message& m)
   at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
   at System.Windows.Forms.ContainerControl.WndProc(Message& m)
   at System.Windows.Forms.Form.WmShowWindow(Message& m)
   at System.Windows.Forms.Form.WndProc(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
    Assembly Version: 4.0.0.0
    Win32 Version: 4.0.30319.18444 built by: FX451RTMGDR
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
CtrlRemapGUI
    Assembly Version: 1.0.0.0
    Win32 Version: 1.0.0.0
    CodeBase: file:///C:/CtrlrRemapGUI_0.6.5/CtrlRemapGUI.exe
    Assembly Version: 10.0.0.0
    Win32 Version: 11.0.50938.18408 built by: FX451RTMGREL
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
System
    Win32 Version: 4.0.30319.34238 built by: FX452RTMGDR
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Core
    Win32 Version: 4.0.30319.18408 built by: FX451RTMGREL
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Runtime.Remoting
    Win32 Version: 4.0.30319.34108 built by: FX45W81RTMGDR
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Remoting/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
System.Data
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_32/System.Data/v4.0_4.0.0.0__b77a5c561934e089/System.Data.dll
System.Xml
    Win32 Version: 4.0.30319.34234 built by: FX452RTMGDR
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
System.Configuration
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Numerics
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Numerics/v4.0_4.0.0.0__b77a5c561934e089/System.Numerics.dll
Microsoft.GeneratedCode
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
    <system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
PLEASE HELP!! Anyone know what to do? I have tried deleting the app an reinstalling no luck.
« Last Edit: September 26, 2015, 04:42:53 am by lisowskikevin »
Re: Controller Remap Utiility - CRAP!!!
« Reply #1 on: September 19, 2015, 07:33:59 pm »
What command line are you using to run ControllerRemap?
It might be that you deleted your ctrlr file, but the command line is still pointing to a given file. If it's not there, I'm not sure what would happen, but an invalid cast is certainly a possibility.
lisowskikevin
« Reply #2 on: September 19, 2015, 07:40:50 pm »
Hey Dr venture!
I'm using the GUI and I clicked on the devices tab and selected one of the aimtrak devices with a super long name. I selected it and clicked backspace and erased the entire thing.
Then I started getting the message. Is there a way to restore it all to normal?
« Last Edit: September 19, 2015, 08:27:49 pm by lisowskikevin »
« Reply #3 on: September 19, 2015, 09:32:46 pm »
Ahhh. Hmm. I'm not sure about that. I didn't write the GUI.
However, yeah, sounds like a node got deleted inadvertently.
Can you post the ctrlr file?
I might be able to figure out what's missing.
lisowskikevin
« Reply #4 on: September 19, 2015, 09:46:17 pm »
Absolutely, I'll find it and post tomorrow. Thanks for your help on this.
lisowskikevin
« Reply #5 on: September 22, 2015, 12:12:02 pm »
Thanks anyways Dr Venture....I just downloaded a newer version of the GUI and I will not be screwing that up! Thanks for your help
« Reply #6 on: September 22, 2015, 01:16:53 pm »
No Prob. Hope that resolves it!
stigzler
    • Mago Arcade
« Reply #7 on: September 22, 2015, 05:54:51 pm »
Ooops - sorry - late to the party. Guessing this is the thing you emailed about, kevin? Is it sorted for you now?
Good job I aint selling it or anything, huh?  ::)
