Author Topic: Aimtrak Lightgun not working in XXXX in 1 gameboard  (Read 3155 times)
chimera123
  • Last login:November 01, 2015, 04:17:06 pm
« on: September 15, 2015, 03:52:17 pm »
Hello,
I have a XXXX in 1 cab with plenty of roms and would like to use my Aimtrak gun for Terminator 2. Joystick and Trackball works well but when I connect the Aimtrak gun things get crazy (Player1 and Player2 are reversed all of a sudden and so on)
On top of it I am unable to configure the lightgun to work with T2. Most of the time I am unable to map it properly and I was never able to get it working in the game to perfrom a calibration. I installed already on my cab the calibration utility and it turned out in windows the lightgun works without any issues, so I am guessing something is wrong with my mame.ini, itīs running on mame 0.145
Hoping somebody can help me to get this works, trying already since days without luck.....tried to set the lightgun to "mouse" or "lightgun" but nothing worked so far.
many thanks
# CORE CONFIGURATION OPTIONS
writeconfig               0
# CORE SEARCH PATH OPTIONS
rompath                   Rom_bios;Roms
hashpath                  hash
samplepath                samples
artpath                   artwork
ctrlrpath                 ctrlr
inipath                   .;ini
fontpath                  .
cheatpath                 cheat
crosshairpath             crosshair
# CORE OUTPUT DIRECTORY OPTIONS
cfg_directory             cfg
nvram_directory           nvram
memcard_directory         memcard
input_directory           inp
state_directory           sta
snapshot_directory        snap
diff_directory            diff
comment_directory         comments
hiscore_directory         hi
# CORE STATE/PLAYBACK OPTIONS
state
autosave                  0
playback
record
mngwrite
aviwrite
wavwrite
snapname                  %g/%i
snapsize                  auto
snapview                  internal
burnin                    0
# CORE PERFORMANCE OPTIONS
autoframeskip             1
frameskip                 0
seconds_to_run            0
throttle                  1
sleep                     0
speed                     1.0
refreshspeed              0
# CORE ROTATION OPTIONS
rotate                    1
ror                       0
rol                       0
autoror                   0
autorol                   0
flipx                     0
flipy                     0
# CORE ARTWORK OPTIONS
artwork_crop              0
use_backdrops             1
use_overlays              1
use_bezels                0
# CORE SCREEN OPTIONS
brightness                1.0
contrast                  1.0
gamma                     1.0
pause_brightness          0.65
effect                    none
# CORE VECTOR OPTIONS
antialias                 2
beam                      2.1
flicker                   0
# CORE SOUND OPTIONS
sound                     1
samplerate                22050
samples                   1
volume                    0
# CORE INPUT OPTIONS
coin_lockout              1
ctrlr
mouse                     1
joystick                  1
lightgun                  1
multikeyboard             0
multimouse                1
steadykey                 0
offscreen_reload          1
joystick_map              auto
joystick_deadzone         0.3
joystick_saturation       0.85
natural                   0
uimodekey                 auto
mouse                   1
joystick                1
lightgun                1
dual_lightgun           0
offscreen_reload        0
steadykey               1
keyboard_leds           1
led_mode                ps/2
ctrlr                   Standard
stickpoint              0
joyid1                  0
joyid2                  1
joyid3                  2
joyid4                  3
joyid5                  -1
joyid6                  -1
joyid7                  -1
joyid8                  -1
# CORE INPUT AUTOMATIC ENABLE OPTIONS
paddle_device             joystick
adstick_device            joystick
pedal_device              joystick
dial_device               joystick
trackball_device          joystick
lightgun_device           mouse
positional_device         joystick
mouse_device              mouse
digital                 j0a0a1,j1a0a1,j2a0a1,j3a0a1
# CORE DEBUGGING OPTIONS
log                       0
verbose                   0
update_in_pause           0
debug                     0
debugscript
debug_internal            0
# CORE MISC OPTIONS
bios
cheat                     1
skip_gameinfo             1
uifont                    default
# CORE MKChamp OPTIONS
disable_hiscore_patch     0
disable_nagscreen_patch   0
disable_loading_patch     0
# WINDOWS DEBUGGING OPTIONS
oslog                     0
watchdog                  0
debugger_font             "Lucida Console"
debugger_font_size        9
# WINDOWS PERFORMANCE OPTIONS
priority                  0
multithreading            0
numprocessors             auto
profile                   0
bench                     0
# WINDOWS VIDEO OPTIONS
video                     d3d
numscreens                1
window                    0
maximize                  1
keepaspect                1
prescale                  1
waitvsync                 0
syncrefresh               0
# DIRECTDRAW-SPECIFIC OPTIONS
hwstretch                 1
# DIRECT3D-SPECIFIC OPTIONS
d3dversion                9
filter                    1
# PER-WINDOW VIDEO OPTIONS
screen                    auto
aspect                    auto
resolution                640x480x16
view                      auto
screen0                   auto
aspect0                   auto
resolution0               640x480x16
view0                     auto
screen1                   auto
aspect1                   auto
resolution1               640x480x16
view1                     auto
screen2                   auto
aspect2                   auto
resolution2               640x480x16
view2                     auto
screen3                   auto
aspect3                   auto
resolution3               640x480x16
view3                     auto
# FULL SCREEN OPTIONS
triplebuffer              0
switchres                 0
full_screen_brightness    1.0
full_screen_contrast      1.0
full_screen_gamma         1.0
# WINDOWS SOUND OPTIONS
audio_latency             4
audio_sync                0
# CORE LANGUAGE OPTIONS
language                  en_US
use_lang_list             1
« Last Edit: September 15, 2015, 03:56:39 pm by chimera123 »
  • Last login:Today at 06:45:10 am
Re: Aimtrak Lightgun not working in XXXX in 1 gameboard
« Reply #1 on: September 15, 2015, 05:59:38 pm »
Did you read the instructions on setting up MAME games?
https://www.ultimarc.com/AimTrak%20Setup%20Guide.pdf
« Last Edit: September 15, 2015, 06:04:10 pm by BadMouth »
chimera123
« Reply #2 on: September 16, 2015, 01:38:32 am »
Hello
Yes, I went through this already a couple of times.
Regarding the lightgun settings in the . ini I am not sure if they are correct, for example "lightgun" is there available 2 times, need to set both to 1? What about the option "mouse" and "lightgun" ?
At this point I was able to correctly map the trigger and bottom for bomb for T2, so shooting is ok.
But it just shoots to the upper left corner, the crosshair is not moving, in game calibration doesn't work.
Strange is that the mapping worked for the X and Y axis but for some reason not when returning to game, same after restart if the game.
thanks for let me know
« Last Edit: September 16, 2015, 01:44:35 am by chimera123 »
« Reply #3 on: September 16, 2015, 07:07:31 am »
Hello
Did you read the specific instructions for T2/RevolutionX in the manual linked above?
« Last Edit: September 16, 2015, 08:58:48 am by BadMouth »
chimera123
« Reply #4 on: September 16, 2015, 01:37:04 pm »
Yes of course, believe me I went through the maual a couple of time, line by line, but in the game the cursor doesnīt move.
When pressing tab I am able to map the gun, but the entries stays grey.
Chimera
Out from the manual:
From mamedev.org: The game will automatically ask you to  calibrate the guns when you start the game for the first time.  Simply put, use your mouse or keyboard to "target" the top  left corner when the game asks so. There aren't any visual  cues to help this, so you'll have to go by the numerical  coordinates that are visible on the screen. The numbers you  see are in a simple 8‐bit scale going from 0 to 255. To  "target" the top left corner, keep moving your mouse until  you get P1 X and P1 Y as near to 0 as possible. The middle is  located at about 127, 127, and the bottom right corner as  close to 255 as possible. Repeat the process for the second  player.
« Reply #5 on: September 16, 2015, 02:09:22 pm »
check in the ini folder located in your MAME folder to see if T2 has it's own ini file.
If there is one there, it will override your mame.ini file.
Multimouse shouldn't make a difference with only one player, but that's something else to try changing.
Those are the only other things I can think of.
chimera123
« Reply #6 on: September 16, 2015, 03:51:42 pm »
Hello,
No .ini file for T2 in the folder. But I found the solution already, pretty simple...now
ADSTICK_DEVICE=Lightgun
Afterwards just calibration in mame and everything works perfectly.
Looks like in a XXXX in 1 gameboard it needs to be setup like this
http://www.mameaddicts.com/phpBB3/viewtopic.php?f=3&t=509
bye
« Last Edit: September 16, 2015, 04:06:41 pm by chimera123 »
