Author Topic: Crt emudriver resolutions problem  (Read 1869 times)
Cisek
  • Last login:May 19, 2023, 07:35:14 am
« on: September 06, 2015, 02:25:34 pm »
Hi
I've installed 6.5 catalyst of crt emudriver and have a really great time with it. I have only one small trouble that boggles me. At all resolutions the image at the top is in "s" shape a little. The tv is Bang & Olufsen MX7000 and surely it is not a matter of bad tv or capkit, because all other gamesystems through scart rgb works fine to the top. Do any of you also encounter this issue? Can it be the issue with the scart cable?
http://postimg.org/image/5z0ism201/
http://postimg.org/image/4hf2h1x9d/
http://postimg.org/image/qhvexofxd/
adder
Re: Crt emudriver resolutions problem
« Reply #1 on: September 07, 2015, 08:08:04 am »
hello, post your groovymame  mame.ini  file here
Calamity
  • Moderator
  • Online Online
  • Last login:Today at 05:29:21 pm
  • Quote me with care
« Reply #2 on: September 07, 2015, 02:33:16 pm »
That's not a software problem. If only a few resolutions had the issue, it could be. Check the way the sync signals mixed in your cable. Your TV might be asking for cleaner sync signals.
Steps to create a log:
