Author Topic: Groovy mame custom monitor specs  (Read 2591 times)
stiegi
  • Last login:January 13, 2020, 04:23:44 pm
  • We learn from experience.
« on: September 04, 2015, 02:44:37 pm »
Hello!
I am using groovy mame 0.149. I recently bought a Siemens TV everything is fine but the picture is shifted to the left.
I tried to change the monitor specs in vmmaker (hfront porch hback porch ..) in order to shift the picture. I use the option
custom monitor in vmmaker.
The problem is that the changes do not affect the picture because when I start groovy mame it writes the message - switchres
could not find a video mode that meets your specs
To put it simple - what settings do I have to take that groovymame actually uses the monitor specs line in vmmaker configuration?
regards,
Calamity
  • Moderator
  • Last login:Today at 09:50:38 am
  • Quote me with care
Re: Groovy mame custom monitor specs
« Reply #1 on: September 05, 2015, 05:12:14 am »
In this post you have instructions on how to port vmmaker's monitor_specs format into groovymame's crt_range format. It's really straightforward.
Steps to create a log:
stiegi
« Reply #2 on: September 05, 2015, 09:46:43 am »
Hello Calamity!
Thanks for your advice. I am going to check this out - I discovered that I overlooked something in mame.ini. There is so much info about
groovy mame out there that it is hard to sort everything out.
I have also found the wiring diagram for my old tv - the picture is so much more "arcade like" than the Sony PVM. There is a trim poti on
the pcb which can adjust picture amplitude (vertical size). For anyone having a specific TV model and can`t find the service manual - first
of all find out what chassis you have got - there are the same chassis for different models and it is easier to find a wiring diagramm for a
specific chassis.
Keep up the good work
Regards,
Alex
