Author Topic: MAME Crash with Wireless XBOX 360 Pad  (Read 2205 times)
Randizzl
  • Last login:September 06, 2018, 02:58:16 pm
« on: September 03, 2015, 02:57:35 pm »
My problem is that I'll program inputs for mame (using mameuifx) for keyboard as well as wireless xbox 360 pads.  I'm not quite sure where it goes wrong, but eventually, if I run mame with the controllers off, and attempt to exit it'll crash, and clear all settings back to default.
Has this happened to anyone else?
Randizzl
Re: MAME Crash with Wireless XBOX 360 Pad
« Reply #1 on: September 09, 2015, 02:09:09 pm »
I can't be the ONLY person this has happened to, can I?
Haze
    • MAME Development Blog
« Reply #2 on: September 09, 2015, 02:41:58 pm »
No, but I did think the issue had been fixed a few years back, so if it's resurfaced that's a bit annoying.
« Reply #3 on: September 10, 2015, 06:52:49 am »
(using mameuifx)
Have you tried just using the latest real mame build?  Sometimes these forks have glitches that mame doesn't.  Or maybe you're using an older version from when it was an issue.
Randizzl
« Reply #4 on: September 10, 2015, 02:09:02 pm »
I'm using mame165.  I set things up in mameuifx, but tried regular mame command line exe as well, and it crashes too.
Randizzl
« Reply #5 on: September 10, 2015, 06:24:51 pm »
Do you have any specific reference to this is an "old" problem?  Know any old threads or possible solutions?
Robbbert
  • Last login:March 03, 2026, 11:30:09 pm
« Reply #6 on: September 10, 2015, 07:18:34 pm »
MAMEUIFX has its own forum. Perhaps if you asked there, the developer may have an answer.
