Author Topic: What are these called:: the 4 screw holes for utrak install  (Read 1001 times)
aldub516
  • Last login:November 29, 2018, 03:32:46 pm
« on: August 26, 2015, 10:57:27 am »
The 4 little eyelets that you pound into a drilled hole in the wood, to Screw the utrak bolts into. Or what's another suggestion for installing a utrak. I was gonna bring it to Home Depot and just find a screw long enough to go into the wood but not pierce the other side. Best suggestion for installing utrak?/trackball? The old bold holders are stuck in my old cp
thatpurplestuff
Re: What are these called:: the 4 screw holes for utrak install
« Reply #1 on: August 26, 2015, 11:04:17 am »
it sounds like you may be referring to T Nuts or threaded inserts
vwalbridge
« Reply #2 on: August 26, 2015, 11:11:44 am »
+1  Scroll half way down on this page to see what options you are looking for:
http://newwiki.arcadecontrols.com/index.php?title=FAQ
megamoze
  • Last login:December 18, 2024, 04:05:59 pm
  • Loving my cabinet, built summer 2015
« Reply #3 on: August 26, 2015, 09:29:26 pm »
the Utrak should have come with the screws and equipment necessary for installation.  I used 3/4" MDF the screws did not even come close to coming out of the other side.
aldub516
« Reply #4 on: August 27, 2015, 09:59:07 am »
It came with everything but once the threaded inserts are in a piece of wood they are pretty much done for so I needed new ones. I just found 4 proper length screws with round flush tops. Works like a charm. Thank you!
