Author Topic: wiring off my power supply  (Read 1596 times)
katuuuz
  • Last login:December 12, 2016, 09:39:44 pm
  • U, U, D, D, L, R, L, R, B, A, Select, Start
« on: August 25, 2015, 11:42:02 am »
Hey there.
So I was wondering about wiring off my PC power supply.  PC is a HP Pavilion s5000.  Can I run my coin lights, and marquee leds and 2 fans off my power supply?  Not sure what they can handle, or if they can get overloaded.  Thanks guys.
Re: wiring off my power supply
« Reply #1 on: August 25, 2015, 02:26:08 pm »
Green Giant
« Reply #2 on: August 25, 2015, 04:20:39 pm »
Hey there.
Need some details on your system.
How many harddrives?  Internal or external graphics card (powered from pcix slot or from power supply)?
Are the coin lights leds and what is the marquee led?  What size fans?
I am leaning towards you are fine, but just need to confirm it.
Toxic Arcade, my first build
JDFan
« Reply #3 on: August 25, 2015, 04:48:16 pm »
Hey there.
From the looks of it the s5000 comes with a measly 220W Power supply so it might be closer to capacity than you think already ( esp. if using a dedicated graphics card rather than the onboard chipset.)
For the stability of the entire setup I'd just invest the $10 for an external Molex powersupply to use for them - something like this one ( http://www.ebay.com/itm/External-Power-Supply-12V-DC-4-Pin-Molex-Adapter-Cable-with-SATA-110V-240V/311345740147?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D33058%26meid%3D87473d5d327246f1a47e8c860c73546e%26pid%3D100005%26rk%3D2%26rkt%3D5%26sd%3D360170366699 )
« Last Edit: August 25, 2015, 04:55:37 pm by JDFan »
katuuuz
« Reply #4 on: August 25, 2015, 05:43:13 pm »
Thanks for the feedback guys.
Using stock hp s5000.  Coin lights are the happ style bulbs, marquee led from groovygames, and I'd grab any 2 fans the stock PS could handle along with those accessories.  Trying to run it all of the one PC so I don't have to hack a power strip or buy a mini power minder...
Green Giant
« Reply #5 on: August 27, 2015, 03:45:05 pm »
Hard to know exactly what a stop s5000 is, but I am going to guess it does not have an external graphics card and it does have a cd/dvd rom drive.
Unplug the dvd drive and if you can replace the happ bulbs with LEDs.  Using that you should have plenty of power to feed what you need to.  Probably still ok with happ bulbs but want to be safe.
katuuuz
« Reply #6 on: August 28, 2015, 09:55:44 am »
Thanks for the reply.  Once the PC is ready to be in the cabinet I was thinking of disabling both cd drives to free up power.  And I am using the stock graphics card.
katuuuz
« Reply #7 on: September 07, 2015, 07:09:45 pm »
What kind of leds would you recommend as happ bulb replacement?
mgb
  • North East, US
« Reply #8 on: September 08, 2015, 09:58:02 am »
You can use standard white leds behind the rejects.
Power them off your 5 volt output.
Each led needs a 68 ohm resistor in series with one leg.
« Last Edit: September 08, 2015, 09:59:57 am by mgb »
