Author Topic: Whats wrong with this monitor?  (Read 1067 times)
berlincam86
  • Last login:January 30, 2020, 10:03:28 am
  • I can't wait to build my first cabinet!
« on: August 23, 2015, 03:46:58 pm »
Ok so I just installed a ebay used chassis in this monitor. Before I has just a line at the bottom of the screen. Now I have this.Any clue what could be the problem? Looks more blue than anything.
baritonomarchetto
  • Last login:Today at 01:26:56 am
Re: Whats wrong with this monitor?
« Reply #1 on: August 24, 2015, 12:44:18 am »
Assuming that the frame of the pic you posted is black (please confirm this...), your blue video output transistor on the neckboard is shorted to ground or your blue cathode in the crt is shorted. You should remove the transistor, turn on the monitor and look if the blue is still dominant (cathode shorted) or missing (transistor bad).
Which monitor is that?
« Last Edit: August 24, 2015, 01:19:35 am by baritonomarchetto »
berlincam86
« Reply #2 on: August 25, 2015, 12:51:48 am »
I'm assuming the cathode is shorted. I tried another chassis and it did the same thing. This is a wells gardner 2792 chassis. Thank you for the help.
