Author Topic: FS: SlikStik Cabinet and Controller + Wells Gardner D9200 -US/Monroe, GA 30655  (Read 1429 times)
bckpack
  • Last login:August 31, 2015, 09:36:05 am
SlikStik Arcade Cabinet
SlikStik Classic Controller
Wells Gardner D9200 - 27" Multisync Monitor
This setup has served me well but it is time to pass it on to someone else who can appreciate it.  This was put together probably 10 years ago but has seen little use. I don't have many options to showcase the monitor anymore, just a BIOS screen. I also have an old Ultimarc ArcadeVGA card (AGP) that I will include. It is the only card that I used to drive the monitor but I don't currently have a working AGP motherboard to test it out.
The cabinet has some swelling from a water leak on the top and rear as pictured but it is not noticeable from the front. The whole thing is very stable.  Monitor bezel and glass is included along with working coin door with token mechanisms. It has some Sony Xplod speakers mounted with red cones that let some light from the marquee through. The marquee bulb does need to be replaced. The trackball mounting plate is peeling a bit but otherwise the control panel is in nice shape. The entire thing just needs a little cleaning and would be easy to get setup and running quickly.
Located in Monroe, GA midway between Atlanta and Athens.  Looking to get $550 for the whole thing.
bckpack
I am willing to split things up, I'm sure there might be more interest in just the D9200 monitor.  I would still prefer not to ship.
Price is negotiable, I just need to make some room.
if/when you part it out and are willing to ship the monitor to Delaware, let me know.
