Author Topic: Best place to order plexiglass  (Read 1225 times)
southpaw13
  • Last login:August 17, 2025, 03:18:15 pm
  • Whatever!
« on: August 19, 2015, 09:46:55 am »
Is it still Tapp Plastics???
Thank😀
aldub516
  • Last login:November 29, 2018, 03:32:46 pm
Re: Best place to order plexiglass
« Reply #1 on: August 19, 2015, 10:28:30 am »
I use lexan for all my plexi needs. Home Depot carries up to 24x36 for pretty cheap if that helps any
  • Last login:Today at 09:07:40 am
« Reply #2 on: August 19, 2015, 10:34:36 am »
I've used Optix or Lexan from Home depot.
You might also want to check with your local glass shop.
My local glass shop rocks.
« Reply #3 on: August 19, 2015, 10:42:42 am »
Home Depot is great when your needed width is less than 24 inches.  Otherwise be prepared to drop 80 bucks for Lexan.
« Reply #4 on: August 19, 2015, 11:21:13 am »
It really depends if you want it tinted or not.  Tapp plastics provides that option.  Home Depot's are clear. Either way Tapp plastics is great and they cut everything to size for you.
D
mgb
  • North East, US
« Reply #5 on: August 19, 2015, 03:29:21 pm »
Tapp plastics is best for variety.
aldub516
« Reply #6 on: August 19, 2015, 06:35:56 pm »
I just checked out their sight for the first time.. Prices are very reasonable.. especially considering the custom cut and no waste. I shall keep this in mind. I can cut lexan no problem minuts a rough edge sometimes. But this could save me time which as they say sometimes, time is money..
