Author Topic: Adjusting Trackball  (Read 1141 times)
chrisindfw
  • Last login:May 09, 2020, 05:57:34 pm
  • I drank what?
Adjusting Trackball
« on: January 05, 2004, 02:27:58 pm »
I was wondering how loose or tight a trackball should be? I have a used one and the rollers are in great condition but I think that the springs that hold the ball centered are a little tight because the ball has some resistance to rolling it. Also the ball is heavy, I dont know how heavy the balls that you would get from happs or ultimarc are.
Just a newbie trying to learn.
TalkingOctopus
    • My Arcade
Re:Adjusting Trackball
« Reply #1 on: January 05, 2004, 02:43:19 pm »
When I first installed my Happ 3" trackball, I screwed it into the mounting plate way too tight.  It did not roll freely for a very long time.  After I loosened the screws it worked much better and rolled like I expected it.  If you have it installed in a mounting plate, you may want to loosen the screws fastening the trackball to the plate.
chrisindfw
  • I drank what?
« Reply #2 on: January 05, 2004, 02:50:02 pm »
See mine is all in an enclosure. I dont have mounting screws... All I have is two springs that hold the wheel in place.
chrisindfw
  • I drank what?
« Reply #3 on: January 07, 2004, 01:20:49 pm »
Anyone know roughly how long a golden tee trackball should spin after a nice hard spin?
Im not talking about the spin where you see the guy take a running start.
bobjohnson77
  • Last login:December 19, 2003, 01:31:47 pm
« Reply #4 on: January 09, 2004, 08:39:48 am »
Can someone answer this for me too! I want to know if my gently used TB is in top shape.  Do they spin for 1 second, 2  or 10? Thanks in advance.
