Author Topic: Rowe R86  (Read 2122 times)
CrazyIan
  • Last login:August 16, 2015, 06:55:39 am
  • R86
Rowe R86
« on: August 16, 2015, 06:01:54 am »
Hi
Jukebox was working fine, however the selections are not working now.  With "service" switch in the "on" position; and the central computer in "test" and "as selected", the "make selection" and "most popular" lights are lit - the number flashing is "100" - but pressing the number keys has no effect.  Any advice?
Also for home pleasure use only, what are the best settings - is it "service" or "ON"; is it "test" or "normal"; and should it be" STD" or "As Selected"?  Thanks for your interest.
Regards
Ian
ami-man
  • Last login:July 19, 2020, 01:22:45 pm
Re: Rowe R86
« Reply #1 on: August 17, 2015, 08:50:30 am »
Hi Ian,
Welcome to the forum.
The service position is for loading records only, for operation it needs to be in the ON position.
For free play switch the normal/test to test.
The order of play is best set to standard, this cuts down on music free periods and mechanism does less revolving around.
If the jukebox does not select as set up above then you have a board issue.
For our customers around the world we ask to be sent the following boards for testing/repair:-
Central Control Computer
Pricing Board
Mechanism Control
Please contact me if you require our services.
Regards
Alan
Alan Hood
ami-man
UK
