Author Topic: MAME Games That Need to be Mapped Manually?  (Read 3360 times)
newoski
  • Last login:February 26, 2021, 07:44:50 am
« on: August 13, 2015, 12:43:31 pm »
Hi Guys,
While 99% of MAME games work after creating a default input config file, I'm noticing that some games still need some manual massage. For example:
20pacgal needs the Start buttons massages because this system had 4 Start buttons. Without massage, it's impossible to start Galaga
PlayChoice-10
Asteroids / Asteroids Deluxe - if using joysticks, buttons need to be remapped to left/right instead of buttons
Any other games come to mind like this?
Re: MAME Games That Need to be Mapped Manually?
« Reply #1 on: August 13, 2015, 12:53:19 pm »
i believe any game that has 6 buttons, like street fighter needs 5&6 buttons mapped for both players.
« Reply #2 on: August 13, 2015, 01:13:07 pm »
Smash TV
Total Carnage
Robotron
If you have a 4-player panel, the co-op games always need changing on my machine to line everything up to the screen properly.  (i.e. the characters on the screen line up with the proper joystick)
Simpsons
X-men
Ninja Turtle series  (I also add the player 1 start button as start since it defaults to button 1 in the real game).
Also, on my setup, I have 7-buttons, so I always change my Mortal Kombat games to be the following:
   HP Block HK
   LP Block LK
Run (only used in MK3)
D
mgb
  • North East, US
« Reply #3 on: August 13, 2015, 01:20:38 pm »
Any alternate play type game like pacman where player one plays then player 2 plays.
A lot of people will use just one stick for 4-ways like that but the game controls still default at left, right, etc for player 1 but R,F,G,D for player 2
  • Last login:Yesterday at 01:53:33 pm
« Reply #4 on: August 13, 2015, 01:21:16 pm »
By default, MAME assumes you have six buttons laid out like this:
123
456
If you wire them that way then most things will already be mapped correctly, including all the 6 button Capcom fighters.
The Midway fighters (Mortal Kombat series & War Gods) will need to be remapped.
If you want the 4 button Namco fighters (Tekken, ???) to be true to the original 4 in a square layout, you'll have to remap them.  Personally I prefer the way they fall with the default MAME mapping.
If you didn't lay out your buttons like that, then anything with more than 3 buttons is going to need remapped.
  • Last login:Yesterday at 10:03:54 pm
« Reply #5 on: August 13, 2015, 01:33:19 pm »
Here's an alternate configuration that works great for Xybots. (the original control panel had twist-to-turn joysticks)
With a 6-button layout like this . . .
123
456
 . . . map the buttons this way:
1. Turn left
2. Fire
3. Turn right
4. Zapper/Start (double-map so you can use either the start button or button 4)
ark_ader
  • I glow in the dark.
« Reply #6 on: August 14, 2015, 04:01:21 am »
StarGate & Defender.
megamoze
  • Last login:December 18, 2024, 04:05:59 pm
  • Loving my cabinet, built summer 2015
« Reply #7 on: August 14, 2015, 04:06:17 am »
I'd love for someone to tell me how to map QBert!  :)
Sent from my iPad using Tapatalk
Ginsu Victim
  • Comanche, OK -- USA
« Reply #8 on: August 14, 2015, 10:19:03 am »
Buy a U360. ;)
