Author Topic: Sony BVM-D32E1WE JPAC SYNC ISSUE  (Read 3300 times)
frankmonk
  • Last login:March 12, 2017, 02:46:28 pm
« on: August 12, 2015, 03:38:21 pm »
update on my sony bvm-d32e1wu
i hooked up my hyperspin pc via j-pac to it but for some reason i cannot get a proper Picture on it
i already tried my mvs and xxxxin1 via the supergun and both Show a nice and clean Image on my bvm
pc is running w7 64bit ati 4890 with crt-emudriver. Resolution is set to 640x480 30mhz interlaced (already tried other Resolution without luck)
j-pac is showing me 15khz Input
tried to set Jumpers on 15 and 31 and also removed all Jumpers from the jpac
i also tried to hook up my sync strike in between but i get the same Picture as well. for some reason it wont sync properly with my bvm d32
i tested the jpac successfully with a hantarex monitor
i also tried to hook up my sync strike in between but i get the same Picture as well:
frankmonk
Re: Sony BVM-D32E1WE JPAC SYNC ISSUE
« Reply #1 on: August 17, 2015, 09:02:00 am »
this has been fixed
deactivated the vcr mode in the Extended menu on my bvm
