Author Topic: optical wiring for steering  (Read 1869 times)
Sgc
  • Last login:January 20, 2018, 04:25:36 am
« on: August 10, 2015, 03:09:50 pm »
Looking for the wiring to the steering wheel optical board of a Indy heat cabinet which i want to set up in a Mame cab
« Last Edit: August 11, 2015, 03:50:16 pm by Sgc »
  • Last login:Today at 05:10:51 am
Re: optical wiring for steering
« Reply #1 on: August 11, 2015, 11:29:46 pm »
Looked for a manual, but didn't find one in the usual places.
What is the part number on the board?  (can't quite read it in the first pic)
Sgc
« Reply #2 on: August 12, 2015, 01:15:39 am »
Will have a look tonight and let you know thanks
Steve
Sgc
« Reply #3 on: August 12, 2015, 01:41:07 am »
Its a wico corp 21-6080 just had a quick look befor work.
Steve
« Reply #4 on: August 12, 2015, 02:59:25 am »
Looking closer at your second pic, the IC appears to be an SN74LS14N. (pgs. 1 and 22)
The dimple is next to pin 1 on the IC. (upper right in your second pic)
Ground goes to pin 7 of the IC (upper left in your second pic) from the top edge-connector contact.
5v goes to pin 14 of the IC (lower right in your second pic) from the 5th edge-connector contact.
That should leave two data lines. (4 wires total in the photo below)
If the cursor moves opposite of the expected direction, swap the data lines where they go into your optical encoder.   ;D
Photo by GaryMcT on KLOV.
Untitled by GaryMcT, on Flickr
« Last Edit: August 12, 2015, 03:01:38 am by PL1 »
Sgc
« Reply #5 on: August 12, 2015, 06:21:42 pm »
Many thanks for the help and information much appreciated just to confirm  from the top of the edge conector top isxground 5 th down is 5volt are the 4 conectors left the data thats 2/3/4/6 have i got that right.  ;D
« Reply #6 on: August 13, 2015, 01:04:40 am »
Sorry, I didn't phrase part of that last post clearly.   :embarassed:
There are 6 contacts on the edge connector, with a total of 4 wires connected. (5v, ground, and 2 data lines)
Edge connector (top is 1)
  1. Ground
  2. ?
  3. ?
  4. ?
  5. 5v
  6. Not used (dead end trace)
The two data lines connect to 2, 3, or 4.
Your board is probably wired with data lines on 3 and 4 like the optical boards in Off Road (pgs 13-15) -- similar looking, but different part number.   :dunno
To verify:
  1. Connect 5v and ground to your optical encoder.
  2. Set your multimeter to volts.
  3. Probe 2, 3, or 4 while slowly turning the encoder wheel.
  4. A data line will alternate between logic high (~3-5v) and logic low (~0-2v) as the teeth and gaps in the encoder wheel block and pass the IR light.
If you don't see changing voltages, you may have a burned out opto-coupler -- look for the IR LED light using a digital camera/cell phone camera. (they pick up IR wavelengths)
Sgc
« Reply #7 on: August 13, 2015, 03:25:49 pm »
Thanks again for the information its a great help, i will let you know how i get on once i get a optipac  as this seems to be the best way for conecting up to the pc.
