Author Topic: Janky Kong - The Final Frontier  (Read 92125 times)
  • Online Online
  • Last login:Today at 06:31:37 pm
Re: Janky Kong - Now in Phase Two
« Reply #200 on: September 17, 2015, 10:13:00 pm »
huh?  ???
Bro, did you even read the last 15 posts?
Yea Chance...everyone knows not to play with their joystick until they lube up their pillow balls.
Pillow balls are exclusive to Nintendo fanbois.
ChanceKJ
« Reply #201 on: September 18, 2015, 02:51:59 am »
How's the guy born in '84 the least childish in this thread?  :P
jdbailey1206
« Reply #202 on: September 18, 2015, 06:36:57 am »
Chance if you don't know about lubing your pillow balls maybe you are on the wrong thread.
  • Online Online
« Reply #203 on: September 18, 2015, 10:46:23 am »
Don't worry, when you hit puberty, your pillow balls will drop down and you'll start manhood.
Oh, and I pulled the trigger on a cheap Vs. Unisystem board. Not even sure if it works, but it's an option...
ChanceKJ
« Reply #204 on: September 18, 2015, 07:00:33 pm »
just make sure you have the proper power, video inverter, Audio amp, and harnesses to connect it all. :)
jugger18
  • Last login:February 25, 2020, 09:58:30 am
  • Time to make a bitchen man cave
« Reply #205 on: September 18, 2015, 07:45:02 pm »
  • Online Online
« Reply #206 on: September 18, 2015, 07:48:19 pm »
jugger18
« Reply #207 on: September 18, 2015, 07:49:03 pm »
Vwall, original WD-40 makes a great flamethrower to get rid of spiders in your garage
vwalbridge
« Reply #208 on: September 18, 2015, 08:04:13 pm »
 :lol you're right about that. Only fire kills spiders.
jdbailey1206
« Reply #209 on: September 19, 2015, 06:42:46 am »
  • Online Online
« Reply #210 on: September 19, 2015, 08:38:47 pm »
Done a LOT on Janky Kong the last few days, and she's almost done. More pics later,  but I had to show what I picked up today... custom built by a talented local woodworker.
« Reply #211 on: September 19, 2015, 10:27:28 pm »
Coin box?
  • Online Online
« Reply #212 on: September 19, 2015, 11:42:54 pm »
Coin box?
Yep. I have to build the enclosure, but the box will help me put together the right dimensions. :cheers:
Oh, man, I'm loving how this has come out.
« Reply #213 on: September 19, 2015, 11:54:53 pm »
I can get actual measurements if needed. All you have to do is ask.
  • Online Online
« Reply #214 on: September 20, 2015, 12:08:07 am »
If you could measure the size of the base, the one that spans the width of the cabinet, I just need to know how deep it is. I'm guessing 10 inches or so?
« Last Edit: September 20, 2015, 12:13:37 am by yotsuya »
vwalbridge
« Reply #215 on: September 20, 2015, 12:15:22 am »
9 and 1/8 inches.
If you trust my chewed-on DK. :)
  • Online Online
« Reply #216 on: September 20, 2015, 12:21:12 am »
Sweet! DeL, if you want to double check, I would appreciate it.
I got a lot to post,  but my phone is going to die. I'll post a few pics, then fill in the narrative later...
« Reply #217 on: September 20, 2015, 09:17:05 pm »
Took some pics with the tape measure. You're in luck since I just gutted my cab to prep it for painting. So I removed the whole coin door box assembly.
« Reply #218 on: September 20, 2015, 09:19:38 pm »
More measurements...
Even measured the handle.
DeLuSioNaL29
  • Online Online
« Reply #219 on: September 20, 2015, 09:26:41 pm »
Thanks, DeL, but you're an hour too late... much appreciated, though...
  • Online Online
« Reply #220 on: September 20, 2015, 09:28:23 pm »
Oh, is the whole enclosure fastened down, or does it just sit there?
« Reply #221 on: September 20, 2015, 09:44:43 pm »
What do you mean by whole enclosure?  If you mean the wood box then, yes, it's stapled in from the bottom onto the plank that spans across the cab.
If you mean the bottom piece of wood, yes, that was screwed into the cabinet.  It was not just sitting there.
D
  • Online Online
« Reply #222 on: September 20, 2015, 09:58:15 pm »
D
I meant the bottom piece. Perfect, I'll fasten it. Thanks!
ChanceKJ
« Reply #223 on: September 20, 2015, 10:10:16 pm »
the batons on the underside of the main plank holding the coin box are screwed into the inside of the main side walls of the cab, two screws each.
  • Online Online
« Reply #224 on: September 20, 2015, 10:14:58 pm »
You might want to link to DeL's photos in the Donkey Kong plans thread. They're really handy.
  • Online Online
« Reply #225 on: September 21, 2015, 10:57:16 pm »
Yeah... so this happened.... I got the board cheap, desoldered the CPU from a bare NES board that I had, and plugged in some EPROMS and a PPU... now I just need to take this to Arcadenut's to test it out..
« Last Edit: September 22, 2015, 12:54:41 am by yotsuya »
ChanceKJ
« Reply #226 on: September 21, 2015, 10:59:13 pm »
Wait... What?
  • Online Online
« Reply #227 on: September 21, 2015, 11:29:06 pm »
« Reply #228 on: September 22, 2015, 12:11:12 am »
I can grab a populated board with full harnesses (including CP harness) for $150 shipped. Is that a good deal?
  • Online Online
« Reply #229 on: September 22, 2015, 12:25:53 am »
A working board, populated with two games, with full harnesses? Snap that ---smurfette--- right up.
« Reply #230 on: September 22, 2015, 12:27:22 am »
Not really. Only 1 side works. (I only need one for my Unisystem). Comes with Tetris. (Don't really care about the game I'm planning to get the UniVersus daughter board when it comes out)
  • Online Online
« Reply #231 on: September 22, 2015, 12:35:06 am »
A working board (no game) seems to run for around $50-$75, and the harness is around $50 (both before shipping). So it really depends on how bad you want the board in anticipation of the UniVersus board. My untested board was $45, and the EPROMs/PPU set was $42 (free CPU). No harness, but I plan to get a Unisystem to JAMMA adapter.
ChanceKJ
« Reply #232 on: September 22, 2015, 12:45:59 am »
Id say thats a decent price. and i'm rather fond of Vs Tetris. Do it.
Wait... What?
Wait... What what?
What exactly are you doing here. and do you have a link that explains more.... ;)
ChanceKJ
« Reply #233 on: September 22, 2015, 12:48:04 am »
I mean, you WILL need a PPU and CPU for the UniVersus.  So why not a PPU that also works with games like Duck Hunt and Tennis?
ChanceKJ
« Reply #234 on: September 22, 2015, 12:48:48 am »
Agreed.  I'll ad them in a bit if J's cool with that?
  • Online Online
« Reply #235 on: September 22, 2015, 12:57:20 am »
What are you talking about? The UniVersus works with any PPU. I picked up a tested, working Hogans Alley PPU/EPROM set. The CPU I got from a gutted NES. It's the same CPU.  :dizzy:
  • Online Online
« Reply #236 on: September 22, 2015, 01:31:11 am »
Oh wait, I see you were talking to DeL. I see I can use my PPU with Tetris as well. I can easily convert the Hogan's Alley EPROMs to Tetris. Hmmmm....
ChanceKJ
« Reply #237 on: September 22, 2015, 03:27:14 am »
Yeah, sorry, I was too lazy to hit the quote button I guess.
Ive got a couple Vs PCBs. One with Wrecking Crew across both, the other with SMB. I plan to populate the WC one with a UniVersus on each side, then use the other with a third U.V. and all the Vs. guts from my DKU cab for my upcoming Mario Bros Cabaret project.
one of the Red Tents will get all the Vs games, the Cabaret will get Mario Games.
ChanceKJ
« Reply #238 on: September 22, 2015, 03:30:49 am »
I guess I was also wondering why you took a CPU from a NES and not just grabbed one from an actual Vs PCB. Like you knew about some cool NES hack or something.
  • Online Online
« Reply #239 on: September 22, 2015, 09:13:50 am »
No cool hacks or anything. My board didn't come with one, and I had this one on hand. Free is free.  :cheers:
