Author Topic: Janky Kong - The Final Frontier  (Read 94236 times)
Re: Janky Kong - Now in Phase Two
« Reply #160 on: September 15, 2015, 09:20:51 am »
Nothing like seeing a repaired CRT fire up... Great Job!
  • Last login:Today at 04:10:26 pm
« Reply #161 on: September 15, 2015, 09:49:14 am »
Good work, man.  It is supremely satisfying to get an old CRT going.
« Reply #162 on: September 15, 2015, 11:05:19 am »
Nothing like seeing it fire up with no fire!
« Reply #163 on: September 15, 2015, 11:05:43 am »
Yeah, especially since the tube is burn free.
rablack97
« Reply #164 on: September 15, 2015, 01:51:26 pm »
« Reply #165 on: September 15, 2015, 03:22:52 pm »
Yep,  baby, I practice on these machines, pretty soon,  we talkin' playoffs!
jugger18
  • Last login:February 25, 2020, 09:58:30 am
  • Time to make a bitchen man cave
« Reply #166 on: September 16, 2015, 01:16:55 pm »
You guys must be drunk
« Reply #167 on: September 16, 2015, 01:17:45 pm »
No, we just have a sense of humor.
« Reply #168 on: September 16, 2015, 10:08:54 pm »
Janky Kong updates from the phone, so one photo per post. It was a good day today, I took the day off work and so I put in a LOT of time with the monitor. I tested the monitor with my TPG, but as I was putting the PC together (more on that later), I plugged in a JAMMA board, hooked it up to a PC supply,  and fired it up. Everything looked great. Then, a couple minutes later, I smelled something. I looked up and saw smoke. Yeah, this happened...
« Reply #169 on: September 16, 2015, 10:15:36 pm »
I'm not sure what caused it to melt. I assume something was shorting out in the bundled up power harness.  I don't know where power was getting to the unused part of the harness, unless power was getting pushed out through the board. Oh well, damn cheap Chinese harness.
However, I made the best of it. The wires for the speakers, door, and player controls were all unharmed,  so I clipped them off and rolled my own harness with an extra Bob Roberts DIY crimp 'em yourself kit that I had. I made my own ground wires to eliminate the issue. So that was good.
But what is this...?
« Reply #170 on: September 16, 2015, 10:19:24 pm »
"That" is a custom board of my own design. I wanted to make an "all-in-one" plate that would function like a PCB. I got measurements and designed a board that would allow me to install the motherboard,  hard drive, AND J-Pac in one convenient place. Here it is with the motherboard installed...
« Reply #171 on: September 16, 2015, 10:20:15 pm »
Here it is with the motherboard and hard drive...
« Reply #172 on: September 16, 2015, 10:21:27 pm »
And now complete....
« Reply #173 on: September 16, 2015, 10:22:42 pm »
So with it all wired up, I plugged the J-Pac into the harness, fired it up, and....
« Reply #174 on: September 16, 2015, 10:36:36 pm »
Nice!
« Reply #175 on: September 16, 2015, 10:51:52 pm »
Art!
Can't say enough about the dedication to make this look and feel like actual arcade hardware!
As you would say,  here's someone who gets it....
Top Shelf bro!
« Reply #176 on: September 16, 2015, 11:18:16 pm »
Art!
Top Shelf bro!
Thanks, brother!
I gotta admit,  when I had the Dell LCD in there, I really hated how it looked. But now... the chuff be flowing.
« Last Edit: September 20, 2015, 11:21:47 am by yotsuya »
« Reply #177 on: September 17, 2015, 01:15:37 am »
Some pics from the end of the night... the last one I'm chuffed by, I printed that sticker out myself!
vwalbridge
« Reply #178 on: September 17, 2015, 10:30:22 am »
That VS control panel and buttons smell minty through my monitor.
« Reply #179 on: September 17, 2015, 10:41:09 am »
The CP is in great shape but nowhere near mint. Half the buttons are original, the others are repros from Mike's Arcade. I need to lube up the P1 joystick. Any suggestions?
vwalbridge
« Reply #180 on: September 17, 2015, 10:50:11 am »
White Lithium Grease
(I think you can also get it at Home Depot)
-Specifically designed for moving metal parts
-Low odor
-Doesn't run or drip
-Doesn't attract dust (this is the best part)
A while back, when operating my garage door it sounded like the world was coming to and end. This stuff applied to the garage door springs and rollers fixed that right up. Great stuff.
WD-40 can eat it.
« Last Edit: September 17, 2015, 10:53:43 am by vwalbridge »
« Reply #181 on: September 17, 2015, 12:26:48 pm »
-Low odor
WD-40 can eat it.
That looks good. Do you think I need to disassemble the stick to use it?
vwalbridge
« Reply #182 on: September 17, 2015, 01:21:50 pm »
I'd probably take the joystick out and disassemble it. Then spray the parts with Carb and Choke cleaner to blast out the gunk...then lube it with the lithium grease. (Only for the metal on metal parts)
If you don't take it apart and there is gunk already in there, then you are just going to put more grease all over the gunk.
« Last Edit: September 17, 2015, 01:25:07 pm by vwalbridge »
vwalbridge
« Reply #183 on: September 17, 2015, 01:24:33 pm »
Pillow balls.... :-[
« Reply #184 on: September 17, 2015, 01:51:05 pm »
Sounds good... and keep your hands off my pillow balls.
vwalbridge
« Reply #185 on: September 17, 2015, 01:59:50 pm »
:lol
I expect a full report when you are done.
« Reply #186 on: September 17, 2015, 03:38:30 pm »
Yeah, white lithium is a good go-to lube. I personally opt for Super lube in most cases because it is well rated for plastics, wood, and rubber as well as metal. I doubt white lithium would corrode plastics, but I generally only see it advertised as a metal-to-metal lube.
I also love to use it on stuff that I touch routinely, because it is a food grade lubricant. I won't worry I am ingesting something i shouldn't if I eat nachos after touching something I lubed up.
dry spray
grease
vwalbridge
« Reply #187 on: September 17, 2015, 03:40:10 pm »
dry spray
grease
I've heard super lube is great too. I'll have to try that sometime.
« Reply #188 on: September 17, 2015, 03:43:13 pm »
dry spray
grease
I'll let you guys know what Mrs. Yotsuya thinks....  >:D
« Reply #189 on: September 17, 2015, 03:48:44 pm »
White lithium got me in the game about caring about my lubes. It took me down a trail from only having a can of WD-40, to having everything from teflon to graphite. Haha! Is it OK to be a "lube snob"?
WD-40 can eat it.
Agreed!! Although, WD-40 is getting into the game of offering real cool products. Picked up a can of this the other day and looking forward to trying it out on everything from NES cartridges to leaf switches.
« Reply #190 on: September 17, 2015, 03:50:23 pm »
 :laugh2: For those certain uses, KY is still king.
vwalbridge
« Reply #191 on: September 17, 2015, 03:53:09 pm »
WD-40 can eat it.
Oh yea, WD is definilty getting with the program now. They have a full product line of lubes. They have even have a WD version of white lithium
I'm curious of your results with the contact spray lube.
« Reply #192 on: September 17, 2015, 03:55:55 pm »
Yots, watch 34ks video here:
He uses the WD-40 Lithium grease shown here:  http://www.walmart.com/ip/40842973?wmlspartner=wlpa&adid=22222222228028406339&wl0=&wl1=g&wl2=m&wl3=61182034809&wl4=&wl5=pla&wl6=96573185529&veh=sem
vwal, are you saying the WD40 brand is not good to use?
D
« Reply #193 on: September 17, 2015, 04:01:07 pm »
Sure, I'll see about giving it a go this week and let you know.  :cheers:
One thing about WD-40, they have really nice nozzles these days. I hate constantly losing those red tube thingies that direct the spray.I might stock up on their white lithium.
I think he is critiquing the original WD-40 formula as a general purpose lubricant. WD-40 can corrode and it only lubricates for a short span. WD-40 works better as a rust buster when removing tough bolts. I would think that many of the WD-40 brand products would be fine.
vwalbridge
« Reply #194 on: September 17, 2015, 04:02:55 pm »
No... I'm sure the WD brand of While Lithium Grease is fine. I just don't like the traditional/general WD for anything.
...and that video by 34K is great.  :cheers: Just change the playback speed in YouTube to like 1.5 because it a little long.
ChanceKJ
« Reply #195 on: September 17, 2015, 08:09:32 pm »
I've always used Dow 33. Figure if its been good enough for 15 years on my paintball guns, it would work well on my sticks.
« Reply #196 on: September 17, 2015, 08:24:17 pm »
Do you put it on your pillow balls?
ChanceKJ
« Reply #197 on: September 17, 2015, 08:35:22 pm »
huh?  ???
« Reply #198 on: September 17, 2015, 08:47:33 pm »
huh?  ???
Bro, did you even read the last 15 posts?
vwalbridge
« Reply #199 on: September 17, 2015, 10:12:23 pm »
huh?  ???
Yea Chance...everyone knows not to play with their joystick until they lube up their pillow balls.
