Author Topic: Golden Tee 2015 hardware build  (Read 3837 times)
caullyn
  • Newbie
  • Last login:August 03, 2015, 10:03:38 pm
« on: August 03, 2015, 08:43:08 pm »
Hey,
I have found some info on building the old cabinet style for Golden Tee. I would like to build something like the current Golden Tee 2015 setup, with an LCD TV and some simple hardware. From the boot screen, I gather that this runs on Linux, but everything I've found in internet searches is a game for windows. I would like to build a computer that can run Golden Tee 2015 and hook up the ball to a simple stand. Any advice or resources is appreciated. If I get through this project, I will post and share a DIY for anyone interested.
DarthMarino
  • Last login:December 17, 2025, 10:53:45 am
Re: Golden Tee 2015 hardware build
« Reply #1 on: August 03, 2015, 09:22:44 pm »
You have to buy a Golden Tee 2015.  That's the only way to run the game.
  • Last login:January 23, 2026, 01:40:05 pm
« Reply #2 on: August 04, 2015, 02:11:07 pm »
there is a golden tee golf game on PC but it is old as dirt (90's goodness). you'd probably be unhappy with it.
for a better Golden tee experience it's best to buy yourself a "for real" golden tee cabinet...see how the cabinet is built and then build your own based on it. (for instance the cabinet control panel has a particular angle to it allow better trackball action.)
I've even cut down a golden tee cabinet and turned it into a pedestal cabinet.
ABACABB
  • Last login:August 26, 2023, 12:37:07 pm
« Reply #3 on: August 04, 2015, 04:02:09 pm »
+1
I've looked into this too.  You can't just install the software, you have to buy the PC hardware from I.T.
