Author Topic: FS: New cab's w/ new parts for multi's (cheap!) Orlando, FL  (Read 991 times)
TimothyC
  • Last login:June 14, 2018, 09:43:43 pm
This post will mainly be a copy & paste from the klov listing.  I have stellar feedback there, as well as 15 years of 100% ebay feedback w/ 1000+ feedback.  I've tried my best to describe any issues with the cab and have potentially overstated the flaws as I want anyone who comes to pick them up to be pleasantly surprised and not disappointed :).  Here goes:
If you're a multicade builder, or want to build one yourself without killing a classic, then these are for you as they're priced at a level that will allow you to finish them for much less than you can buy one from CL.
The cabs are/were new and come with a populated cp. They also have new bezels and marquees (many of which still have the protective brown paper on them).
However to finish these cabs they will need a power supply, jamma harness, 60 - 1 board (or whatever multi you want), a new back door, new locks, and a day's worth of elbow grease. Even though all the cabs are/were new, while they were in storage some jagoff broke in and pried the back door off each and cut the harness that was there (probably for scrap) and removed the pcb if it was there as well. Only a few have back doors and they have some damage from being pried off (and some of the cabs have damage on the back as well from their removal) One of the cabs was clearly dropped quite hard so it's rough and priced accordingly. None of them are pristine, but most are still very nice.
I'm asking $175 for 1, $150ea for 2, or make an offer for the lot of 8 (though I'm probably keeping two for a friend). There is one missing a chunk out of the side toward the back (probably due to the door being pried off) that I would sell for $100 and the one that was dropped is just $50 (it's still a usable cab as is, but it's damaged).
Pros:
New cabinet (or formerly new now I suppose )
Populated cp that has a hole for a trackball though it's covered by the plexi cpo
NEW marquee (two styles available: Pacman or multithemed) some still have the brown protective paper on them)
NEW multicade bezel (some still have the paper of them as well)
19" Dell LCD already mounted (I checked the date on one & the date of manufacture was 2012 so they may all be new or barely used)
New coin door
Negs:
None of them are perfect anymore as all have a some wear somewhere and some more than others
The overall fit and finish on these is not up to hardcore vintage collector CQ standards
The coin doors don't have mechs
A couple of the coin doors (not all, so I'll have to take a closer look tomm & report back) have an odd coin acceptor plate (korean?) that has a cheap feeling return lever
Some arsehole thought it would be a good idea to jigsaw away most of the monitor shelf since he was installing LCD's.
Some, but not all of the plexi cpo's have bowed up slightly (a little liquid nails in the right spot is the perfect ghetto fix :P)
You have to see my ugly face upon pickup
