Author Topic: VGA to Component DIY?  (Read 1094 times)
djfender
  • Last login:April 13, 2020, 04:13:15 pm
  • I play with sega, not ladies' hearts.
« on: July 28, 2015, 02:43:42 pm »
I was wondering if there existed a circuit to convert VGA 640x480P @ 31khz (PC/Dreamcast Standard) to Component YPbPr (640x480i @ 15khz)
Or Two Circuits put together Like:
31khz > 15hkz (DownScaler)
RGB > YUV Circuit
I.E Take the bone standard 31khz video signal from a computer, preform some some magic voodoo, take it down to 15khz RGB, then some more mystic voodoo to turn a 15khz RGB signal into a 15khz YUV signal.
The RGB to YUV Circuit's pretty easy to wrap your head around...
If not, a cheapo HDMI2AV will work, but this won't work with dreamcast... http://www.amazon.com/Generic-Converter-Adapter-HDMI2AV-Support/dp/B00P12BOO8/ref=sr_1_3?s=electronics&ie=UTF8&qid=1438108915&sr=1-3&keywords=HDMI2AV
« Last Edit: July 28, 2015, 02:54:39 pm by djfender »
Is that a Sanwa in your pocket or are you just happy to see me?
"Hotrodded" Hanaho Hotrod w/Kade MiniArcade 2.0 on Leonardo
Re: VGA to Component DIY?
« Reply #1 on: July 28, 2015, 03:07:59 pm »
are you trying to go from DC to arcade?
Buy a VGA box and snip the #7 wire
SavannahLion
« Reply #2 on: July 30, 2015, 12:25:43 am »
Where did you find that circuit?
MonMotha
« Reply #3 on: August 01, 2015, 12:23:37 am »
As I recall it's on ePanorama or similar.  Note that it does not handle sync.  You'll need to output SoG or come up with a way to put sync on the Y output.
