Author Topic: T molds without the T ?  (Read 1139 times)
shayvidas
  • Last login:March 28, 2016, 09:18:22 pm
  • mame Fan Forever !!!
« on: July 27, 2015, 04:11:06 am »
i'm looking for a T mold but without the T (the thing i need to do a groove for), do you know where i can find somthing like that ?
also how do i attach it to the side then ?
Re: T molds without the T ?
« Reply #1 on: July 27, 2015, 07:41:41 am »
its called "edge banding" and it has adhesive.
http://www.t-molding.com/3-4in-black-edgebanding.html
vwalbridge
« Reply #2 on: July 27, 2015, 08:23:18 am »
I've seen guys cut the spine off with a razor and then use glue to hold it down. But that's pretty crappy looking and certainly doesn't last. Not to mention a big PITA. Might work OK if it was a short distance without curves. Even better in an area that doesn't see much wear.
What is the application? I'm curious why regular t-molding with a spine will not work?
« Last Edit: July 27, 2015, 08:30:38 am by vwalbridge »
« Reply #3 on: July 27, 2015, 08:31:37 am »
My Offroad Thunder cab had edge banding and not t-molding, from the factory.  The application could be on anything you cant cut a slot into i guess.
SavannahLion
« Reply #4 on: July 27, 2015, 08:35:08 pm »
They probably used the wrong glue. The glue I've seen used is super tacky. It reminds me of cross between rubber cement and book glue.
behrmr
  • Last login:April 23, 2021, 09:17:13 am
« Reply #5 on: July 27, 2015, 11:49:18 pm »
I've worked on a Japanese cocktail table that used edge banding on the table top.  It's actually a lot less stressful than fitting t-molding.  You just peel and stick and then trim with a quad-cutter if you need to.
megamoze
  • Last login:December 18, 2024, 04:05:59 pm
  • Loving my cabinet, built summer 2015
« Reply #6 on: July 28, 2015, 12:05:59 am »
T-molding gives out free samples to try.  I ordered a couple of different samples, including the adhesive one.  Should be an interesting test.
kpop
  • Last login:April 24, 2020, 11:30:13 pm
