Author Topic: Rowe Storm CD wallmount  (Read 2319 times)
The Record Machine
  • Last login:August 22, 2015, 06:52:12 pm
« on: July 25, 2015, 08:02:15 pm »
Recently acquired a Rowe Storm Jukebox, WP 100 and it has a Pro 2 Cd player. Can someone give me the proper way to clean/ service this player. Appreciate the help. RM
« Last Edit: July 26, 2015, 07:10:44 pm by The Record Machine »
lilshawn
  • Last login:February 14, 2026, 11:45:41 am
Re: Rowe Storm CD wallmount
« Reply #1 on: July 27, 2015, 11:50:38 am »
doing a full service involves a pretty complicated disassembly, clean, and lubrication of parts. if the cd's are gripping and loading/unloading properly and the disks read. It's good.   basically if it works, don't mess with it. a tiny bit of isopropanol alcohol on a cotton swab to gently clean the lens is really the only regular maintenance you need to do.
if you go crazy and start spraying moving parts with WD-40 to lube stuff up, it will work, but you end up attracting more dirt and gumming things up making a huge mess to clean up that can literally take HOURS.
most of the stuff runs unlubed to keep dirt buildup and grime down. very few parts actually require lubrication...and even then it's tiny tiny amounts.
resist the urge to get the compressor out and blow the hell out of the player...you'll end up with dust inside the laser assembly (not a sealed unit) and you'll have to replace it (it's not disassemblable.)
ami-man
  • Last login:July 19, 2020, 01:22:45 pm
« Reply #2 on: July 28, 2015, 11:53:50 am »
Hi lilshawn,
Good advice there, I hope the poster heeds your advice.
Regards
Alan
Alan Hood
ami-man
UK
