Author Topic: Ultimarc MiniPac Shifted Keys Problem  (Read 891 times)
newoski
  • Last login:February 26, 2021, 07:44:50 am
« on: July 25, 2015, 04:07:24 pm »
Hi Guys,
My MiniPac is acting up. The normal key functions work fine. Shifted are all over the map.
When I unplug/plugin the USB cable to the MiniPac, the LED flashes once, turns off a few seconds, and then turns on and stays solid green.
Here's where things get weird, some Shifted keys work fine, some keys don't work at all, and some keys work but send the wrong Shifted input. 1 key is duplicating the Shift input of another working Shifted key.
If I use WinIPAC Test Mode, Switches 1-6 for each player are recognized, but they are sending the wrong keys -- ignoring my programming.
Any help would be greatly appreciated!
