Author Topic: how to change 6 pin molex connection to 15 pin D-sub  (Read 1672 times)
rock145
  • Last login:November 07, 2021, 02:05:20 pm
« on: July 23, 2015, 07:19:26 pm »
Hi, I am going to buy this WELLS GARDNER MODEL # 25K2193 monitor I want to know if is possible to make 15 pin D-sub connection to the monitor to connect to pc.
Re: how to change 6 pin molex connection to 15 pin D-sub
« Reply #1 on: July 23, 2015, 07:51:04 pm »
Yes, it's possible, but you need to make sure your video card is putting out the correct signal.
rock145
« Reply #2 on: July 23, 2015, 08:09:18 pm »
Thanks for the reply. I don't know much about arcade monitors could you provide me with a guide,tutorial or video on how to do this. About the video card I can use ati 4360 with groovymame.
rock145
« Reply #3 on: July 24, 2015, 02:44:57 pm »
Will this http://www.ultimarc.com/store/section.php?xSec=11  VGA Breakout Cable work? Are these only compatible with arcavga cards only or can I use it with ati cards and groovymame.
