Author Topic: how to change 6 pin molex connection to 15 pin D-sub  (Read 2839 times)
rock145
  • Last login:November 07, 2021, 02:05:20 pm
« on: July 23, 2015, 05:10:19 pm »
Hi, I am going to buy this WELLS GARDNER MODEL # 25K2193 monitor I want to know if is possible to make 15 pin D-sub connection to the monitor to connect to pc.
Paradroid
  • Last login:July 12, 2025, 08:11:33 pm
    • SCART Hunter
Re: how to change 6 pin molex connection to 15 pin D-sub
« Reply #1 on: July 24, 2015, 01:44:10 am »
Can't see why not. Just map the R, G, B, H-Sync, V-Sync and ground lines from your chassis to the corresponding VGA pins. Tie the RGB and sync grounds (from the VGA connector) together and you should be fine.
Sent from my SM-A300Y using Tapatalk
rock145
« Reply #2 on: July 24, 2015, 11:23:25 am »
Thanks for the reply. I don't know much about the workings of arcade monitor. Can you provide me with a diagram,tutorial or guide on how to do this?
rock145
« Reply #3 on: July 24, 2015, 02:45:41 pm »
Will this http://www.ultimarc.com/store/section.php?xSec=11  VGA Breakout Cable work? Are these only compatible with arcavga cards only or can I use it with ati cards and groovymame.
Paradroid
    • SCART Hunter
« Reply #4 on: July 24, 2015, 03:58:27 pm »
The VGA pins aren't going to change between different video cards so, yeah, should work fine. :)
If you're confident with making cables, you could definitely build your own. Otherwise the Ultimarc product should be a good bet.
Do you have a picture of the 6 pin Molex connection? Crimping pins for a header is a little more involved (since you need the right parts and tools) but if you have an existing cable you could splice it and solder the D-Sub connector on the end. Happy to show you how...
rock145
« Reply #5 on: July 24, 2015, 04:03:23 pm »
Thanks for your willingness to help. I don't have the monitor I just wanted to know if it was possible before I buy it. As soon as I get it, I will update my post.
Paradroid
    • SCART Hunter
« Reply #6 on: July 24, 2015, 04:05:26 pm »
Oh, right! Definitely possible, one way or another. :)
jtslade
  • Last login:February 13, 2025, 10:06:51 pm
  • Keep it looking originallish!
« Reply #7 on: July 24, 2015, 10:25:40 pm »
Maybe just grab a spare vga cable and your multimeter continuity mode. Strip all the wires and use the bag pinout diagram
Ms. Pacman Original Cocktail with Non destructive mod to Groovy Arcade Linux with All 4way Vertical Cocktail capable 2 button or less games.
Neo Geo MVS Mame Cab Running Hyperspin, 25" Nanao Arcade Monitor, Mini-pac, ATI Radeon HD 4850 (ATOM-15), IL 8 Way Euro-Sticks from Paradise Arcade, Win XP 64bit, and tons of other junk.
