Author Topic: Artwork on/off button assignment, duplicate rom  (Read 1700 times)
sshaw10
  • Last login:July 11, 2021, 12:51:40 am
  • Oops!
« on: July 22, 2015, 01:07:35 am »
I'd like to be able to turn artwork off/on with a button assignment, maybe have mame cycle through the video options with the push of a button.  I thought about cloning a rom and adding art to the end of the rom and artwork files so you would have two versions of the same game in the list, one without artwork and one with but that involves editing the mame xml and gets complicated and time consuming.  Don't think there's a way but thought I'd check.
Thanks.
Re: Artwork on/off button assignment, duplicate rom
« Reply #1 on: July 22, 2015, 03:52:53 am »
I'm curious as to why you'd want to do that.
big10p
  • Last login:May 01, 2023, 01:46:23 pm
  • Mmmm, arcade classics!
« Reply #2 on: July 22, 2015, 06:49:39 am »
I'd guess the only way would be to hack the source code.
« Reply #3 on: July 22, 2015, 07:28:34 am »
for the rom thing, yeah
To toggle art on or off, it could theoretically be done with an autohotkey script.
Easiest solution? 2 MAME configs, 1 with art, 1 without
sshaw10
  • Oops!
« Reply #4 on: July 22, 2015, 09:12:49 pm »
yotsuya,
I wanted to do this because some of the artwork makes the game really small and sometimes I'd want to play with and sometimes without all the artwork, or maybe with just an overlay and not the bezel.  What I'm ultimately trying to do is make the experience as easy as possible without having to go through menus or use a keyboard.  Pushing a button to cycle through art setups would be the easiest.
Malenko,
when you say 2 configs, do you mean two of each rom or two different mame installs all together and then just switch emulators?  I tried duplicating roms then adding art to the end of the duplicated name and doing the same for the artwork file.  I then had to edit the mame xml file to have the duplicate listed as a game and that got complicated, not as easy as making a duplicate of the game and changing the name.
Thanks for the responses.
« Reply #5 on: July 22, 2015, 09:16:38 pm »
yotsuya,
Malenko,
Cool, I get it. I play with the artwork cropped so I don't have the size issue. I see it as screen filler.
Good luck!
« Reply #6 on: July 22, 2015, 10:21:01 pm »
Malenko,
2 MAME installs sharing the same ROM directory.  1 MAME install with art, one without.  switch which MAME you use based on if you want art or not.
sshaw10
  • Oops!
« Reply #7 on: July 23, 2015, 01:34:02 am »
Good idea Mal, I'll give that a try.
I kneel before thee.
keilmillerjr
  • Web Developer.
« Reply #8 on: July 23, 2015, 04:44:29 am »
Core Artwork Options
-artwork_crop
-use_backdrops
-use_overlays
-use_bezels
-use_cpanels
-use_marquees
Create an autohotkey (assuming you are using windows) that will:
Accept params
Determine if your service button is pressed
Add additional params if necessary
Launch mame with params
