Author Topic: Test mode  (Read 2198 times)
androtaz08
  • Last login:October 09, 2024, 07:17:01 am
Test mode
« on: July 20, 2015, 07:55:39 pm »
I just noticed the other day that my desktop says its in test mode. I know that I had to enter test mode during they install. Does this have to stay this way?
Slippyblade
Re: Test mode
« Reply #1 on: July 20, 2015, 08:24:53 pm »
You've provided no actual information here.  What OS you got?  What is the exact wording of the msg?  What install - was it clean install, update, upgrade?
androtaz08
Re: Test mode
« Reply #2 on: July 20, 2015, 10:18:32 pm »
Sorry, Its a clean install of windows 7 Ultimate.
Paradroid
  • Last login:July 12, 2025, 08:11:33 pm
    • SCART Hunter
Re: Test mode
« Reply #3 on: July 20, 2015, 11:58:34 pm »
The "test mode" watermark is completely normal (as mentioned in the driver installation guide) and it can't be removed as it's necessary to allow the hacked driver to work.
Dr.Venom
  • Last login:May 08, 2018, 05:06:54 am
Re: Test mode
« Reply #4 on: July 21, 2015, 03:44:37 am »
The test mode is indeed required for the driver to work, but the watermark can be removed while staying in test mode.
See here: http://deepxw.blogspot.co.uk/2008/12/remove-watermark-v03-build-20081210.html
It's a hack, so use at your own risk.
haynor666
  • Last login:November 21, 2025, 05:45:00 pm
  • retro maniac
Re: Test mode
« Reply #5 on: July 21, 2015, 05:57:18 am »
I tested this hack with Win 7 x64 Home Premium some time ago and works great.
