Author Topic: Mame 0.163 + mamewah 1.69 cannot generate All games roms list  (Read 3302 times)
Pitou
  • Last login:July 01, 2025, 12:33:17 pm
Hello,
Since version mame 0.162, I cannot generate the "AllGames" roms list anymore with Mamewah 1.69. It works fine with mame 0.161
Here is what Mamewah log says:
When it works:
2015-07-18 22:51:47 List generation started...
2015-07-18 22:51:47 Current drive/directory selected: D:\mame
2015-07-18 22:51:47 Commandline run: C:\Windows\system32\cmd.exe /c D:\mame\mame.exe -listxml > D:\mamewah\mame.xml {flags=81}
2015-07-18 22:52:37 Application quit: C:\Windows\system32\cmd.exe /c D:\mame\mame.exe -listxml > D:\mamewah\mame.xml
2015-07-18 22:52:58 List generation finished
2015-07-18 22:52:58 Games list read: mame-0.lst
When it doesn't work:
2015-07-18 22:59:35 List generation started...
2015-07-18 22:59:35 Current drive/directory selected: D:\mame
2015-07-18 22:59:35 Commandline run: C:\Windows\system32\cmd.exe /c D:\mame\mame.exe -listxml > D:\mamewah\mame.xml {flags=81}
2015-07-18 23:00:50 Application quit: C:\Windows\system32\cmd.exe /c D:\mame\mame.exe -listxml > D:\mamewah\mame.xml
2015-07-18 23:01:20 List generation aborted
2015-07-18 23:01:20 Games list read: mame-0.lst
Maybe there is something with the fact that MESS and MAME merged.
I also tried RomLister and when generating "All Roms", it doesn't allow to create a list.
It would be a neat option to generate the full list from Romlister.
Any idea?
Thank you.
Pitou!
adder
Re: Mame 0.163 + mamewah 1.69 cannot generate All games roms list
« Reply #1 on: July 19, 2015, 02:52:17 am »
*deleted*   ;)
« Last Edit: July 19, 2015, 02:56:22 am by adder »
haynor666
  • Last login:November 21, 2025, 05:45:00 pm
  • retro maniac
« Reply #2 on: July 19, 2015, 04:44:03 am »
XML format has been changed and MAMEWAH just like many other frontends needs update.
Pitou
« Reply #3 on: July 19, 2015, 01:24:07 pm »
That explains. Thank you very much!
Pitou!
NOP
  • Last login:September 19, 2017, 08:22:27 pm
  • I stole my avatar.
    • winterMAME
« Reply #4 on: July 20, 2015, 02:33:23 pm »
1) click the "list all roms" button
2) highlight all of the roms in that list (click on the first game in the list and then scroll to the end of the list and click on the last game while holding the shift key)
3) right click on the list and select "add to your list"
4) now you have a list you can export to any format you want
Pitou
« Reply #5 on: July 20, 2015, 10:11:22 pm »
Worked like a charm! Thanks very much NOP!
Pitou!
