Author Topic: Killer Instinct and MAME 163 - Anyone have random sound stutter?  (Read 3378 times)
delt31
  • Last login:August 01, 2020, 03:11:10 pm
For the life of me I can't figure out why.  It's not all the time but generally right before the fight begins (character doing their FMV and then right before the match opens, sound stutter) and during a fatality move - basically the transistion from end of match to fatality.  Does anyone else have this?  I'm running a beast of a pc (980 gtx) too.  Pretty much just KI.  Any suggestions? I've tried vsync, synch to monitor refresh speed, etc.
ark_ader
  • I glow in the dark.
Re: Killer Instinct and MAME 163 - Anyone have random sound stutter?
« Reply #1 on: July 18, 2015, 11:28:36 pm »
You might need to turn off unnecessary services that are running in the background.
You could have a Monster PC, but bottlenecks are abound in Windows, especially Vista.
Try running it in Tiny XP and see if KI still has a sound issue.
WindDrake
  • Last login:December 03, 2020, 09:49:05 pm
  • Electrical Engineer
« Reply #2 on: July 19, 2015, 02:51:06 am »
Just checked on two machines. No issues. One is my gaming rig (i7-960, R6870) and the other is my big 4-player MAME cab (Phenom II X3 3.0@3.7, R5750).
haynor666
  • retro maniac
« Reply #3 on: July 19, 2015, 04:58:42 am »
This was already posted some time ago. Search forum ;)
delt31
« Reply #4 on: July 19, 2015, 02:54:51 pm »
I checked and no answer was given.
I have nothing running in the background. for guys who get no stutter, try hitting orchid off the stage - no stutter right before it happens?  If not, please send me your display and sound settings.  Maybe it's that. I've tried so many without luck...
EDIT _ so some progress.  If I turn on refresh speed and set the hz to 60 manually, i get rid of almost all the randomness (before fight, hit off stage).  It still skips during the end of the long intro (transistion from into to demo stage) but I can live with that random one...
« Last Edit: July 19, 2015, 03:10:31 pm by delt31 »
haynor666
  • retro maniac
« Reply #5 on: July 19, 2015, 04:01:33 pm »
I have set frame_delay 2 and mt on. On G3258 4,2 GHz I didn't noticed any sound distortion.
delt31
« Reply #6 on: July 19, 2015, 04:15:35 pm »
thanks but what is MT?  Frame delay would not make it run as smooth as original no?  I'm assuming frame delay is frame skipping in options right?
haynor666
  • retro maniac
« Reply #7 on: July 19, 2015, 04:20:04 pm »
Multithreading.
delt31
« Reply #8 on: July 19, 2015, 04:59:10 pm »
Multithreading.
OK I have that turned on (set to 1).  Is my understanding of your frame delay correct?  That's basically a frame skip right?
haynor666
  • retro maniac
« Reply #9 on: July 19, 2015, 05:26:38 pm »
Nope
This is the only option where the Groovy MAME user must really make an extra effort of testing and configure the emulator in a per-game basis in order to get the best possible emulation out of it (particularly, regarding the input lag issue), since this feature is heavily dependent on the computer's CPU and the usage every emulated game in particular makes of it.
The frame delay feature actually serves two purposes:
- Delaying the emulation of a frame in order to get the most up-to-date input state before going into the emulation itself
- Bypassing a frame queue that's built in the ATI video drivers when Direct 3-D API is used which adds a lag of 2-3 frames by itself
delt31
« Reply #10 on: July 19, 2015, 06:01:55 pm »
Nope
Interesting never heard of it.  I'm using mameguifx and I don't see this option.  wonder if it's even possible in that program
haynor666
  • retro maniac
« Reply #11 on: July 20, 2015, 02:07:22 am »
Groovymame exclusive ;)
Long time ago I had problem with laserdisc games - unstable speed vary from 97% to 103% and frame_delay 2 helped.
delt31
« Reply #12 on: July 20, 2015, 08:22:20 am »
Might need to try it out.  Really like mamegufx as it has that lottes CRT shader already embedded into it.  If I can someone get that to work with groovy, I'll do it.
delt31
« Reply #13 on: July 23, 2015, 06:36:56 am »
well KI is still stuttering even w/my refresh speed on.  damn - if anyone else has a suggestion (besides an exclusive feature to one mame program), lmk.
