Author Topic: Polo Hantarex 25" no red  (Read 2440 times)
Bunnyuk
  • Last login:May 20, 2017, 05:52:20 am
« on: July 12, 2015, 06:55:13 am »
Hi guys,
I recently purchased a gaming machine and the Monitor is as above.
I have no real red in street fighter for ken or the health bars, they just appear black.
If I adjust the red cut off on the neck board the main screen will go red tintish instead of black but the life bars and ken are still black.
The red gain doesn't appear to do anything either when adjusted.  I've had a new Lopt fitted and checked all simple cabling from the red cable output on the monitor to the jamma loom.
I believe the engineer also replaced this third transistor (capacitor) in the pic.
Where do I go from here? Please help.
jtslade
  • Last login:January 22, 2026, 03:19:42 pm
  • Keep it looking originallish!
Re: Polo Hantarex 25" no red
« Reply #1 on: July 12, 2015, 10:33:54 am »
Do you have another Jamma board to test with? Or the TPG from Crafty?
Ms. Pacman Original Cocktail with Non destructive mod to Groovy Arcade Linux with All 4way Vertical Cocktail capable 2 button or less games.
Neo Geo MVS Mame Cab Running Hyperspin, 25" Nanao Arcade Monitor, Mini-pac, ATI Radeon HD 4850 (ATOM-15), IL 8 Way Euro-Sticks from Paradise Arcade, Win XP 64bit, and tons of other junk.
jtslade
« Reply #2 on: July 12, 2015, 10:34:16 am »
Have you checked all voltages
baritonomarchetto
  • Last login:January 27, 2026, 02:19:44 am
« Reply #3 on: July 12, 2015, 11:39:27 am »
Run your monitor WITHOUT a video signal: what color your raster is? If it's white, the color problem is in the PCB,  if it's cyan the prob is in the monitor and it's highly probable that replacing the red video output transistor will solve
Bunnyuk
« Reply #4 on: July 12, 2015, 12:34:11 pm »
Hi JtSlade,
Unfortunately I don't have another game board to test.
What are the correct voltages and am I testing everything on the chassis or just the neck board?
Cheers
Bunnyuk
« Reply #5 on: July 12, 2015, 03:28:25 pm »
When I checked VDC I got two of the three transistors at 60 ish
The third located on the left on the pic was 34?
grantspain
« Reply #6 on: July 13, 2015, 01:34:21 am »
out of interest where did you get the monitor chassis
normally a colour missing is something physically broken on the neck card
it could be drive transistor or the lm1203 ic
also do what a previous post mentioned,disconnect the video signal and then use the screen volts to obtain a raster-then adjust each cut off pot to see if you get that individual colour saturate the screen
Bunnyuk
« Reply #7 on: July 13, 2015, 04:01:34 am »
From VideoTronics in the UK.
How do I  'use the screen volts to obtain a raster'?
Also where do I find the transistors / resistors and IC chip?
Bunnyuk
« Reply #8 on: July 13, 2015, 08:20:10 am »
I'm going to replace all 3 resistors and the three drive transistors on the neck board.
Can anyone help with exactly what I need to buy from say maplin or Rs components.
The Resistor looks like it says 6k8 and on hantarex schematics for the neck board it says 1/4w (watt I presume)
Not sure on the transistors?
grantspain
« Reply #9 on: July 13, 2015, 05:54:18 pm »
does it have a small circular holo microdot on the heatshield,if so this is a chassis i did for mo last week and the grey load resistor was snapped from the neck card-probably find its been whacked in shipping and done it again
Bunnyuk
« Reply #10 on: July 15, 2015, 09:11:20 am »
 Hi GrantSpain,
That's the one, did you test the red?
The pic on the monitor was superb and I was told a new lopt had been fitted.
Did you fit a new ic1 lm1203 as also looks new?
Just no red :-(
Could it be the colour drive transistors if not resistors?
grantspain
« Reply #11 on: July 15, 2015, 01:19:09 pm »
unless that has been damaged in shipping its not a chassis fault,it was working perfectly when it left me
your next step is to locate the red cut off pot on the neck card and adjust it to see if the screen saturates with red
Bunnyuk
« Reply #12 on: July 15, 2015, 02:55:47 pm »
It does saturate with red.
I've noticed the ribbon cable looks iffy on the soldering?
grantspain
« Reply #13 on: July 15, 2015, 03:13:36 pm »
nowt wrong with that,ok so your red signal is most likely missing then
now go to the video signal plug and swap the blue and red over-see what happens
Bunnyuk
« Reply #14 on: July 24, 2015, 08:58:28 am »
Hello guys,
With the amazing help of GrantSpain I have a top working monitor again.
Infact the problem was related to the Graphics Card.
Thanks for all the posts and help on this.
Cheers
