Author Topic: Concfusion between vmmaker monitor_spec and groovymame crt_range's  (Read 1729 times)
jamesm801
So I'm confused as to which of these to use.  I was going along using ArcadeOSD to configure resolutions, setting up my monitor_specs in the vmmkaer.ini.
I'm using super resolutions
Do I also have to covert these to crt_range's and put them into mame.ini as well?  Or can't groovymame just assume I've put my mode lines in with vmmaker and choose the correct one without me having to specify this in two places.
Sorry I'm a newb, not sure how this is supposed to work.
Calamity
  • Moderator
  • Last login:Today at 05:14:58 pm
  • Quote me with care
Re: Concfusion between vmmaker monitor_spec and groovymame crt_range's
« Reply #1 on: July 11, 2015, 08:48:24 am »
GroovyMAME can't guess your vmmaker settings, you need to port those to crt_range format. Future versions of vmmaker will use the crt_range format so it'll make things easier.
Steps to create a log:
