Author Topic: FS: Raspberry Pi B+ 1st gen - ** SOLD **  (Read 938 times)
dweebs0r
  • Ascendo tuum!
« on: July 08, 2015, 05:54:53 pm »
Raspberry Pi B+ for sale.  Perfect for emulation projects.  Small form factor.  Payment via paypal.
If you PM and I don't respond immediately, email me at jnewell@gmail.com
The Model B+ is the final revision of the original Raspberry Pi. It replaced the Model B in July 2014 and was superseded by the Raspberry Pi 2 Model B in February 2015.
Compared to the Model B it has:
  • More GPIO. The GPIO header has grown to 40 pins, while retaining the same pinout for the first 26 pins as the Model A and B.
  • More USB. We now have 4 USB 2.0 ports, compared to 2 on the Model B, and better hotplug and overcurrent behaviour.
  • Micro SD. The old friction-fit SD card socket has been replaced with a much nicer push-push micro SD version.
  • Lower power consumption. By replacing linear regulators with switching ones we’ve reduced power consumption by between 0.5W and 1W.
  • Better audio. The audio circuit incorporates a dedicated low-noise power supply.
  • Neater form factor. We’ve aligned the USB connectors with the board edge, moved composite video onto the 3.5mm jack, and added four squarely-placed mounting holes.
The Model B+ is perfectly suitable for use in schools: it offers more flexibility for learners than the leaner Model A or A+, which are more useful for embedded projects and projects which require very low power, and has more USB ports than the Model B.
« Last Edit: July 11, 2015, 09:48:44 am by dweebs0r »
Slippyblade
Re: FS: Raspberry Pi B+ 1st gen - $22.50 shipped - (Munford, TN)
« Reply #1 on: July 08, 2015, 09:43:55 pm »
email sent
dweebs0r
  • Ascendo tuum!
« Reply #2 on: July 11, 2015, 09:48:28 am »
Sold.
