Author Topic: Dreamcast NTSC/PAL/Regional Encoding  (Read 2882 times)
Grasshopper
  • Last login:March 04, 2025, 07:13:36 pm
« on: January 02, 2004, 08:37:37 am »
I've seen some good Dreamcast game deals on the web (also I haven't forgotten about you email Snaaake) but many of the games are coded for NTSC regions and I own a PAL Drramcast.
From what I've been reading, I understand that I can play Japanese or American region (i.e. NTSC) games if I purchase a boot disk or a mod chip. So far so good. But I've also read that if you run an NTSC game on a PAL Dreamcast, the Dreamcast will still output a 60 hz NTSC signal. Can someone confirm whether this is true or not. This is important as I'm using an old TV which is almost ceretainly not dual-sync.
Is is also true that all Dreamcasat games (both PAL and NTSC) can be run on a computer monitor using a VGA convertor. This might be a way round the problem.
Thanks in advance.
Dave_K.
  • Last login:July 06, 2022, 03:27:30 pm
    • Arcade Fever
Re:Dreamcast NTSC/PAL/Regional Encoding
« Reply #1 on: January 02, 2004, 05:58:11 pm »
Hmm...I know the boot disc will allow US people to play JAP and PAL games...not sure about the other way around.  I think the game must be coded to support 50hz (but I could be wrong).  What I do know is that the VGA adapter will let you play US/JAP/NTSC games on your computer monitor just fine.  There are a couple games which have a problem with VGA but its just a couple.
