Author Topic: CRT Emudriver - W7 - installation issues  (Read 6106 times)
lettuce
  • Make It So!
« on: July 04, 2015, 02:49:54 pm »
Im trying to install the CRT Emudrivers but after the setup has finish im getting a message saying..
"No driver package was installed"
should i be getting this message?
EDIT: I have a HD4670 btw
« Last Edit: July 04, 2015, 03:00:13 pm by lettuce »
adder
Re: CRT Emudriver - W7 - installation issues
« Reply #1 on: July 04, 2015, 03:54:51 pm »
Im trying to install the CRT Emudrivers but after the setup has finish im getting a message saying.. "No driver package was installed" should i be getting this message? EDIT: I have a HD4670 btw
are you installing catalyst version 9.3? also which OS are you using?
lettuce
  • Make It So!
« Reply #2 on: July 04, 2015, 04:37:11 pm »
No Catalyst 13.1, im using windows 7 64Bit
  • Last login:Today at 03:16:11 pm
« Reply #3 on: July 04, 2015, 05:35:41 pm »
No, you shouldn't be getting that message. That happens when something's gone wrong during the process. Try again. Check this: http://geedorah.com/eiusdemmodi/forum/viewtopic.php?pid=334#p334
lettuce
  • Make It So!
« Reply #4 on: July 04, 2015, 08:08:15 pm »
Thanks Calamity, The CRT Emudrivers i installed was the ones at the bottom of this first post....
http://geedorah.com/eiusdemmodi/forum/viewtopic.php?id=65
It was a fresh install of Win 7 x64 as well and i removed the 4670 driver that windows installed before hand. I have a question though does CRT Emudriver, VMMaker & Arcade_OSD 1.4 all have to be in the same folder when running the CRT Emudriver setup.exe file, as i just had the CRT Emudriver files in its own folder?
« Reply #5 on: July 05, 2015, 06:07:19 am »
They don't need to be in the same folder.
Check the forum, there are some long threads about the issues with W7 installation, every possible error should be covered there.
Example: http://forum.arcadecontrols.com/index.php/topic,138903.msg1435608.html#msg1435608
big10p
  • Mmmm, arcade classics!
« Reply #6 on: July 05, 2015, 07:38:48 am »
When installing the CRT emudriver, remember NOT to restart your PC when prompted to, else the installation fails. Maybe this is what you did?
lettuce
  • Make It So!
« Reply #7 on: July 05, 2015, 09:21:32 am »
Yeah ive skimmed over that thread but all the issues brought up seem to be for after the drivers actually been installed....im falling at the first hurdle and cant even get the driver installed!
Yeah it doesn't even ask me to restart, it just pops up with that message that no packages were installed
« Last Edit: July 05, 2015, 10:09:07 am by lettuce »
« Reply #8 on: July 05, 2015, 10:28:49 am »
Do you have UAC enabled?
lettuce
  • Make It So!
« Reply #9 on: July 05, 2015, 11:29:09 am »
Im not 100% sure, what ever its set as from default as its a fresh install...should it be enabled or disabled?
« Reply #10 on: July 05, 2015, 12:26:44 pm »
Please describe a bit the sequence of messages, texts and questions you get to see before that.
lettuce
  • Make It So!
« Reply #11 on: July 05, 2015, 04:25:58 pm »
Well thats the only error message i have gotten. From my fresh install of windows 7....
created a mame folder which i placed GroovyMame in
created a ini file for GM
created a folder for CRT Emudriver and place the files in the folder
created a folder for VMMaker & Arcade_OSD and place the files in the respected folders
went into control panel>Hardware>device manager and uninstalled the AMD drivers that windows installed
then ran CRT emudriver setup.
It completes the setup but then gives me the "No driver package was installed" message
« Reply #12 on: July 05, 2015, 04:44:43 pm »
There are several steps in there before that message appears. Things that you need to accept, etc. I'm trying to help you.
big10p
« Reply #13 on: July 06, 2015, 08:15:53 am »
Also, remember to run the installer as an admin.
AMDman13
  • Last login:April 08, 2023, 09:21:58 pm
  • This Cab is going to be the end of me!!
« Reply #14 on: July 06, 2015, 08:29:01 pm »
Also, I would use Safe mode to uninstall the Amd drivers.
My old user name was marlborroman13, but I kicked the habit many years ago!
Kornerblok
  • Last login:April 22, 2020, 08:32:20 am
« Reply #15 on: November 03, 2015, 06:12:52 am »
hi, did Lettuce get this fixed? I have exactly the same problem and have followed the steps exactly. It comes up with No driver package was installed". I am using a HD4350.
Kornerblok
« Reply #16 on: November 04, 2015, 06:40:52 pm »
update...after rebooting pc, it began installing the drivers automatically and is now ok. Not sure why it didn't work following the steps, but the reboot did it.
« Reply #17 on: November 10, 2015, 03:55:23 am »
Sometimes, it seems that this is the case, because the Calamity certificate is not validated after a reboot, and as a consequence the driver is then loaded. I know this sounds a bit random but it's the best guess I can do from the distance.
