Author Topic: M2lagfix Setup  (Read 4989 times)
Gamer4life
  • Last login:June 28, 2024, 01:02:32 am
M2lagfix Setup
« on: June 26, 2015, 12:21:46 am »
I am almost done with my twin build(build thread coming soon) I have everything up and running im just trying to get m2lagfix setup to get rid of the flashing cars. I used the setting from this post:
http://forum.arcadecontrols.com/index.php/topic,133283.80.html
I cant get the two to link up. Has anyone else have this up and running on just a 2P setup? Any help would be great.
TIGER8855
  • Last login:January 19, 2026, 06:02:38 pm
Re: M2lagfix Setup
« Reply #1 on: July 15, 2015, 10:19:01 pm »
I'd be interested in this as well. I have read thru the whole thread and couldn't figure it out.
MrThunderwing
  • Last login:January 29, 2026, 05:20:57 pm
Re: M2lagfix Setup
« Reply #2 on: July 16, 2015, 07:10:37 pm »
http://forum.arcadecontrols.com/index.php/topic,133283.msg1459251.html#msg1459251
5a. YOU NEED A 8 PLAYER NETWORK! IT DOES NOT WORK WITH LESS UNITS YET :)
I think you'll have to stick with the standard network version for the time being. Have you tired enabling Framsync in your network .ini to see if that helps?
Brian74
  • Yep... I built that!!
Re: M2lagfix Setup
« Reply #3 on: July 16, 2015, 08:49:56 pm »
Gamer4life
Re: M2lagfix Setup
« Reply #4 on: July 23, 2015, 12:37:49 am »
The reason I asked was because she stated that it would work with any setup.
Hi dozer, the lagfix works in any setup.
vandale
  • Id 10 and t error
Re: M2lagfix Setup
« Reply #5 on: July 23, 2015, 01:38:01 am »
Not really applicable as the lag is in game only, not on attract screen. Can you post a video showing the cars not flashing when in multiplayer.
SailorSat
  • Last login:January 23, 2026, 04:28:07 pm
    • For Amusement Only e.V.
Re: M2lagfix Setup
« Reply #6 on: July 23, 2015, 07:28:25 am »
m2lagfix does work with any amout of units. the 8 player requirement was/is for the live spectator feature.
please note: flickering cars most likely happen with framesync=0 (or not defined at all) in m2network.ini
you could try framesync=1 first, but you will most likely get network hiccups (all games freezing for like 1-3 seconds) every now and then.
try these...
m2network.ini #1
[Network]
RxPort=9101
NextIP=127.0.0.1
NextPort=9102
FrameSync=1
m2lagfix.ini #1
[m2rx]
LocalHost=<network ip #1>
LocalPort=7001
RemoteHost=127.0.0.1
RemotePort=9101
[m2tx]
LocalHost=127.0.0.1
LocalPort=9102
RemoteHost=<network ip #2>
RemotePort=7002
m2network.ini #2
[Network]
RxPort=9201
NextIP=127.0.0.1
NextPort=9202
FrameSync=1
m2lagfix.ini #2
[m2rx]
LocalHost=<network ip #2>
LocalPort=7001
RemotePort=9201
[m2tx]
LocalHost=127.0.0.1
LocalPort=9202
RemoteHost=<network ip #1>
RemotePort=7002
Boomslang
Re: M2lagfix Setup
« Reply #7 on: July 23, 2015, 03:27:10 pm »
None of my pcs freeze up while using framesync=1 while racing network
All of my pcs are pretty fast with i5 cpu's in all of them
vandale
  • Id 10 and t error
Re: M2lagfix Setup
« Reply #8 on: July 24, 2015, 02:30:26 am »
Do your cars flash occasionally?
Nuexzz
Re: M2lagfix Setup
« Reply #9 on: July 24, 2015, 03:39:48 am »
Oh my God!! Therefore edit inis take away the desire to try a. pdf to the local and the network is needed. This is a mess, why give up trying (although you see the dialog box m2lagfix became green) I not found the difference rival cars were following crazy  :dunno
« Last Edit: July 24, 2015, 03:42:06 am by Nuexzz »
Nuexzz
Re: M2lagfix Setup
« Reply #10 on: July 24, 2015, 03:50:43 am »
I love to use this patch m2lagfix in my "m2netplay" with kaillera (but managed to not get success) ???
