Author Topic: How do I keep the ArcadeOSD resolution after shutdown?  (Read 2024 times)
alomar123
  • Last login:June 15, 2017, 01:36:25 pm
« on: June 25, 2015, 09:09:16 am »
After searching for an hour I can't figure this out. I am using ArcadeOSD to pick the resolution that I like in 15 hz and am playing MAME games. However, whenever I shutdown the computer, it reverts back to the original resolution. How can I get to a place where, after I turn on my computer it will eventually go to the 15 hz resolution I picked in ArcadeOSD? Or is it easier just to keep the computer always on? BTW I have windows 7 and use HyperSpin.
Thanks in advance
  • Last login:Today at 12:23:45 pm
Re: How do I keep the ArcadeOSD resolution after shutdown?
« Reply #1 on: June 25, 2015, 09:30:32 am »
In Arcade OSD, use the option "set as default display mode".
If that doesn't work, select the mode in the w7 display properties dialog, advanced, show all modes.
alomar123
« Reply #2 on: June 25, 2015, 09:53:18 am »
Thanks, I will try both of those when I get home.
« Reply #3 on: June 25, 2015, 09:56:18 am »
Please try first with Arcade OSD if you don't mind.
big10p
  • Mmmm, arcade classics!
« Reply #4 on: June 25, 2015, 11:23:41 am »
Not sure if this makes a difference but, have you set ArcadeOSD to run as an administrator?
