Author Topic: How to set up two Turbo Twist2 spinners in mame to run at same time ?  (Read 2290 times)
Rattus
  • Last login:February 03, 2026, 07:06:52 pm
I'm thinking of building a CP with two spinners that can also be used for top down racing games etc, I want it to be a basic panel that I can place over my Astro City CP and plug into USB on my PC, then just lift off when I'm finished to play the standard original joystick CP.
What concerns me is that I have read how XP doesn't recognise two mice at the same time and I have tested plugging two mice into my XP-64 with Groovymame cab and they both control the same pointer.
So does buying the Master and Slave Turbo Twist2 fix this issue so that they both plug into USB and can be used for separate inputs? Is this easy to configure in MAME and supported by all MAME versions?
Has anyone done this and can offer some experienced advice?
Rattus
DarthMarino
  • Last login:December 17, 2025, 10:53:45 am
The encoder board allows up to 3 Turbo Twist 2's.  Wire one to the X-axis and wire the other (slave) to the Y-Axis. You'll have no problem mapping them in MAME.
Rattus
Thanks for that DarthMarino, I will order them from GroovyGameGear tomorrow :)
