Author Topic: Rowe AMI r85 blowing fuses  (Read 2310 times)
djbruno
  • Last login:June 08, 2015, 10:10:38 pm
« on: June 06, 2015, 07:14:04 pm »
My Rowe AMI R85 Juke Box keeps blowing out the 250a fuses.   Does anyone know what may be causing this to happen.   I will try to attach a photo of the unit that has the fuses underneath.
« Last Edit: June 06, 2015, 07:15:46 pm by djbruno »
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
Re: Rowe AMI r85 blowing fuses
« Reply #1 on: June 09, 2015, 03:11:53 pm »
fuses are an intentional weak link .
passing current in excess of it rating will cause the element to open .
thereby removing power to the affected circuit and eliminating risk of further damage/fire.
the fuse(s) in question indicate what circuitry is involved.
only replace with the same type/rating as indicated .
i.e. DONT put a 20A fuse where it should be a 2
or worse ... a bolt
seen this far too many times by DIYers    :soapbox:
